Question about Sharp CD-BA2600 CD Shelf System
I have no antenna and radio doesn't play. I need an antenna or specs on the plug to make my own
    President:
  • Sharp Master
  • 1,114 Answers
Looking at Sharp's site, you have a 3 pin plug that goes into the rear of the unit. the top pin is FM the middle and bottom are AM. You can get female "bullet" connectors and make your own if you wish. Or you can order it from Sharp. Probably under 20. Hope this helps
Posted on Jun 26, 2009
I replaced my ford Radio with another factory radio remaufactured. I plugged in the 2 plugs and the antennas, only the clock works. It will take CDs but won't play them, radio doesnt go to radio,
Modern automotive electronics are keyed to the VIN through the ECU to prevent theft, you must have the radio ID #, and key it into the radio with the number pads on the radio, only the dealership can retrieve the correct code for your vehicle. Probably not what you wanted to hear.
Sep 08, 2012 | 1999 Ford Explorer
My 1994 geo tracker 2 door auto runs great all the light work but the radio doesn't.
The least costly problem would be the radio fuse located in your Tracker fuse box/block. You can see a visual of the fuse box location in your owners manual. Next would be someone has switched out the radio at some time and did not reconnect the power line. As the radio does not light up at all, this is a power radio problem...if your radio light up but does not play, it could be your antennae is not plugged in to the back of your radio. If you have to remove the radio, there are many good radio shops that should test your radio for power, for free...Best Buy is usually helpful. Hope this helps.
Jun 11, 2012 | Cars & Trucks
Hi, the receiver reads antenna not found. I know the radio itself is working as my husband plugged his Blackberry into it and played Pink Floyd. Also, the receiver is not lighting up like it used to when...
If the screen is dim, then try a new antenna. Dim screen = shorted antenna connection. If that doesn't solve it, sell it for parts on eBay, you'll get like $5-$20 depending on if it's subscribed.
Sep 09, 2011 | Sirius Starmate ST2 Satellite Radio...
What is wrong with a satellite reciever when all I am getting is aquiring signal displayed
This indicates that the antenna is not gathering enough of the signal to be played. This can be caused by an obstruction between the antenna and the satellite in the sky ie: tall buildings, heavy tree cover, covered garage, etc. It can also indicate a problem with the antenna itself, the cable between the antenna and the radio, the connector on the end of the cable or in the radio or, a problem with the antenna circuit inside the radio.
Since there's little you can do about the last item in the list, check the other parts of the antenna for damage. A pinched or crushed cable will short out the antenna signal - and the voltage sent to it by the radio. If allowed to persist for very long, damage to the radio could result. Look for breaks in the outer jacket of the cable - water entering the cable will cause corrosion and will degrade the signal, too. If you find a problem with any part of the antenna system, about the only thing you can do is replace the antenna completely. You can get a replacement online for as little as $9 and change.
Before installing, try connecting the antenna to the radio with the antenna exposed to ta clear view of the sky in a location that you were able to receive a signal before. If it works, you're done. If it doesn't - the problem is internal to the radio and will need to be repaired - or replaced.
I hope this was helpful - if it was - please rate it "4 thumbs up" Thanks!
Aug 02, 2011 | Sirius Radio Receiver
My sirius kt-sr3000 also works fine in car dock, but when inserted into it's plug+play boom box,boom it displays "antenna not detected"
Try swapping the boombox antenna with the car dock to see if you get the same problem. If yo do, you know the boombox is bad. Otherwise, its the antenna and you just need to get a replacement.
Jun 13, 2011 | JVC KT-SR2000 SIRIUS Radio Receiver
Cant get radio to play stops on station wont pick up antaina hooked up
Check if the antenna male plug is completely plugged into the antenna port of the car stereo.If it is plugged well in the car radio but don't pick stations then your antenna cable is bad.You need to install a new set of antenna,available at any car audio supply.
Jan 30, 2011 | Sony Car Audio & Video
Sony xplod am/fm cd model cdx-m610 will play cds but the radio want play. i have tried to reset radio still will not play
Make sure that you have the antenna plugged in and if you have a power antenna make sure that you hook up the solid blue antenna wire behind on the radio harness to the power antenna wire from the car plug.
May 21, 2010 | Sony CDX-M610 CD Player
USA SPEC PA11-Vol unit will not play iPod using the iPod cable.
where did you plug this behind the radio ? or at the cd changer cable ?, the interface needs to be plug into the radio not the cd changer cable
Dec 20, 2009 | USA Spec (PA11-VOL) for iPod
Cant pick up any radio stations after battery was changed
probably need the anti-theft code to get the radio working again
Jul 15, 2017 | Sony CDX-M600 CD Changer
Sharp CD-BA2600 CD Shelf System Logo
678 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
