Question about Asko 24 in. D3112 Free-Standing Dishwasher
Asko D3121 overfill protection Problem
Hi Guys
I had the same problem as all of you above, in my case nothing to do with pump. I moved house and this problem started with ASKO D3121 dishwasher. can only be stopped with main power off and make hell of noise but there is no water ....
5 Suggested Answers
  • 42 Answers
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
SOURCE: Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Posted on Mar 17, 2010
  • 351 Answers
SOURCE: i need instructions for d3121
look up asko.com.au,
Posted on Jun 02, 2010
ginko
  • 19396 Answers
SOURCE: My Asko D3121 dishwasher won't turn on. When
Hi.
There is no error code, then check the following:
1)Check that the problem is not overflow.. Remove the lower access panels and check the tray under the dishwasher. If you find it is full of water use a cloth to dry water. Test the overfill switch.
2) Disconnect power, move the appliance forward and check that the drain and inlet hose is OK. Be sure that the machine is filling. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray.
3) Test the door lock. This can be tested jumping its contacts.
4) If all the rest is OK you may have a defective control module. This is not a common fault. Ensure that all the rest is OK first, wiring and pump motor must be tested before going for control module.
Start checking for overfill, that is a very common fault that may cause cycle not starting
If you want to contact a technician use the number listed on the USE AND CARE GUIDE.
Regards.
Ginko.
Posted on Apr 26, 2011
What does the Code C3 mean on my Asko Dryer
Here is the list for the DRYER not sure what model... guys please post MODELS!!!!!!!!!!!!!!!!!!!!!
Asko
Dryer
Failure Code Condition Check/Repair
F1 Condensate drain overfilling.
1. Check condensate reservoir pump and drain tube.
F2 Maximum drying time exceeded (3hrs) 1. Check for tripped circuit breaker or blown fuse
2. Check ductwork for lint build-up
3. Check hi-limit and cycling thermostat
4. Check heating element
F3 Thermistor fault 1. Open thermistor, replace
2. Bad wiring to thermistor
F4 Too much lint in the lint filter, front housing, or in the condenser.1. Clean lint from lint filter and/or condenser
F5 Fault in the moisture sensor ยท Lint covering sensor in front of housing1. Bad sensor
2. Bad wiring to sensor
Sep 26, 2014 | Asko Dryers
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Apr 06, 2009 | Asko 24 in. D3121XL Free-standing...
Pump is always running on my Asko D3121 even when door is open. the pump works OK when I put water in dishwasher but never stop
check the float switch ... it is under the dishwasher it could be stuck in the up postioin or you can have water under the dishwasher..
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 16, 2008 | Asko 24 in. D3120 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Oct 08, 2008 | Asko Dishwashers
Remove the backpanel of the machine, and look if there is water at the bottom of the machine. If so, use a towel or so to dry up the water. This should solve the prob.
Nov 06, 2007 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 1796 F2 problem
It sound like you have a blocked or a malfunction pump. Remove the pump from the machine and check whether you have a clogged inside the pump or in one of the pipes connected to it. In case all is clean, you should replace the pump.. Good luck !
Aug 27, 2007 | Asko 24 in. D3250 Built-in Dishwasher
ASKO Overfill protection tripped
Ok, heres what you have to do. Remove the lower toe kick and then remove the panel behind that to gain entry to the lower portion of the dishwasher wher the guts are. You will also have to pull out the little brackets that hold the toe kick and all the screws will be t-15 or t-20 torx (little star shaped bits) Once you have all the panels out of the way, you will find water in the bottom of the tray there tripping the overflow switch. Remove the water with a wet vac or towel or something and the drain pump will stop running. If you can't or don't want to do all this, then just let the dishwasher sit for a few days or so and eventually the water will just evaporate and everything will work normally. Hope This Helps!
Nov 24, 2006 | Asko 24 in. D3112 Free-Standing Dishwasher
Asko 24 in. D3112 Free-Standing Dishwasher Logo
295 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
