Question about Sony XM-2002GTR Car Audio Amplifier
A blue light is on on my amp and there is no sound coming out of my subs what should i do i checked all the wires. it didnt turn on when i started my car, then i went to my friends house and turnd the car off then turne it back on and the subs started to work again, then when i started driving i turned up the sound and the amp stoped working
  • rteemon
    rteemon May 11, 2010
    check to see when your remote source is coming sound like to me base on wht you explain you have the wrong circuit for remote
  • 54 Answers
Very likely the amp is overloaded and goes into protective thermal shutdown. Letting it cool off for a little while would allow it to reset. could be it's not capable of sustained power level you like. Next most likely reason is miswiring speakers - if you have more than one and they are in parallel (the usual case, with all the red+ terminals wired together and all of the black- terminals wired together), check to see that their total impedance is no less than the minimum specified in the amp's manual. The total impedance is Z=1/(1/Z1)+(1/Z2)+(1/Z3)... where Z1 is the impedance of the first speaker, Z2 the second, etc. For example, two 4 ohm speakers in parallel = 2 ohms.
Posted on Jun 26, 2009
I just bought a hifonics amp the brz2100.1D and when i tryed to hook it up every thing is correct as far as the wireing compared to the manual and the blue lights come on power light is on but its not...
MAKE SURE YOUR GROUND WIRE IS GROUNDED GOOD,,AND IT IS IMPORTENT TO HAVE YOUR REMOTE WIRE HOOKED UP. IT WILL BE A BLUE WIRE,,FIND THE HOT WIRE FOR YOUR TAIL LIGHTS AND HOOK IT THERE THEN WHEN YOU TURN YOUR CAR ON THE AMP WILL ALSO COME ON.THAT SHOULD STOP ALL THE NOISE AND POWER YOU UP.
Jul 15, 2011 | Hifonics BRZ21001D Car Amp
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Amp worked fine one day and the next day i get nothing. the red light on the side is on but i dont get any sound. i took the subs that were wired on that amp and wired them on the other punch 800 i have...
did you check all fuses on amp and coming from battery power wire? also check the ground and rca cables connecting to the unit and make sure the remote wire (small blue wire) didnt come lose thats usualy a sign for the red light
Mar 26, 2011 | Rockford Fosgate Punch 800a2 Car Audio...
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
Amp power wire is going to battery with a fuse, remote wire is hooked up to the solenoid. The amp and sub work fine when the key is on, but when i start the car, the amp light dont come on but there is...
The remote wire goes to the back of the radio to blue remote or pwr antena blue wire, solenoid? No idea ..Is the amp on all the time, the radio is suppose to turn it on and off..
Mar 05, 2018 | Rockford Fosgate Power 351M Car Audio...
Hi i turn the amp on and the green light turns on but no sound comes out from the sub
You need to check the wiring of the sub or the box. If you have done that successfully than look at the rca cables and the blue antenna wire running from your deck to your amp
Jun 14, 2010 | Kicker 06ZX750.1 Car Audio Amplifier
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
Basicly my speakers were working fine, my subs were working fine but everytime i was turning my volume up to a certain level i would lose all base and all noise from the subs in my boot, so i turned it...
The amp should always light up showing you that it is powered and there will also be a red light that will light up if theres something wrong.Sounds like maybe the hot wire that goes to the amp isnt big enough to give the amp enough power.Check your positive wire and ground wire for tightness and make sure hot wire supply is big enough and also the ground wire is big enough and has a good ground.I hope this Helps you.Have A great day..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 31, 2009 | Pioneer GM-X722 Car Audio Amplifier
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
Sony XM-2002GTR Car Audio Amplifier Logo
246 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
