Question about Carrier 38CKC036 Air Conditioner
Compressor fan cycles on and off .1986 carrier mo#38eh0363300l
Fan runs about 10 seconds and turns off . Comes back on for 10 seconds and turns off again Repeats cycle over compressor. It has a black round thing that looks like a start up capacitor and a silver cannistor in the wiring department. Are either one of these things bad? Please reply J.R. Peters
    Problem Solver:
  • 7 Answers
If your compressor is working continously, you most likely have a hi/lo fan cut out switch. What is the temp outside? If the temp is not real hot, it's normal for hi/low cutouts to cycle. You may need to adjust the pressures of the hi/low cutout and will need guages.
Posted on Jun 26, 2009
    President:
  • 2,692 Answers
Usually compressors cycle on and off due to the low preasure switch which disconects the compressor when their is a freeon leak. Put the gages on it and see if the preasures are correct.
Carrier 38CKC036 compressor will not cycle after initial run.
Does it have a low pressure switch. It sounds like it is a pressure switch issue
May 16, 2014 | Carrier 38CKC036 Air Conditioner
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 23, 2017 | Heating & Cooling
I have a Carrier 58SX060 Furnace with air. I turned the thermostat to heat and the exhaust comes on and runs and the pilot comes on but the burner never light s and the blower never comes on. If I turn the...
carrier gas furnaces will try to light three times then will usually go on a lockout for one hour you can bypass the lock out by resetting the power, turn furnace on, remove wires from gas valve, you will need a multi meter to check for voltage to valve, if control board sends a call to the gas valve the valve is bad, if voltage is never present during the lighting cycle your control board is bad
Sep 30, 2009 | Heating & Cooling
Small frig stopped
are you sure the compressor is running or is it just humming trying to start then clicking out on the overload, if so you have a 50\50 shot of the relay being bad, otherwise the compressor is shot
Jul 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fan wont turn off
the control board is bad safety feature of carrier board . Tom
Jun 29, 2009 | Carrier 38CKC042 Air Conditioner
Side by side not cold
compressor overheated or stuck. also check starter relay...maybe broke.
if ever thing is alright,
let it stand for about 4 hours unplugged to cool the compressor.
plug it after 4 hours and if the compressor would still run for 10 seconds, then you have a faulty compressor.
tnx 4 using fixya,
drcool
Sep 09, 2008 | Kenmore Refrigerators
Central Air Conditioner
Turn the power to the indoor unit off. Remove the cover where the fan is. Feel the motor of the fan. If it is very hot the bearings have likely gone out. If the fan is cool to the touch I would call a service company because you likely have an electrical problem that will require some training to solve.
Jul 09, 2008 | Carrier 38CKC042 Air Conditioner
COLMAN TSR
3000 Watts is a little short on the power necessary for the compressor to restart. When it compressor starts it may draw 27 amps or more for a split second. 3000 / 120 = 25 amps. when the fan slows down it is telling you the voltage has dropped and it doesn't have enough power. After the pressure has balanced out in the A/C system the compressor can start against no pressure difference.
Jun 16, 2008 | Coleman Mach 15 Air Conditioner
Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Apr 22, 2008 | Frigidaire 9 cu. ft. / 255 liter Chest...
Carrier 38CKC036 Air Conditioner Logo
271 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
