Weatherking gas furnace and need help with transformer wiring
I have a weather king furnace that i recently replaced the transformer which doesnt have a fusible link to save it incase it wants to blow up. It also has a relay on it. the trans. has 2 primary power wires white and black and it also has brown red and black secondarys. now im the second person to put a transformer on this unit. the blower dosnt seem to be working right so im wondering if its wired right. the blower has a white wire that goes to a capacitor, a black one a green one and a brown one. which one goes to which?
  • Dennis Boxerman May 11, 2010
    In alot of cases, the wiring can be found right on the lable of the motor. Other times, the wiring decal is on the inside of the one of the panels. Check it out.
  • 52 Answers
On 120v units most likely will be white should be common,black should be hot,brown to capacitor, and green to ground transformer sounds to be wired correctly.
Posted on Aug 25, 2009
My weatherking 90 furnace that is about 12 yrs old will not ignite the system works but will not ignite. The ignightor however glows hot. Thanks.
Hello, make sure the gas valve is opening and the burners are getting gas and verify that the gas valve is getting 24 volts.
Feb 15, 2011 | Weather King Heating & Cooling
Weatherking Furnace will now turn on. Can get blower to work
Does your outside unit run. Does the inside unt try to run. If not you may have control problem. Check voltage on transformer. It should be 24 volts. Rus
Mar 20, 2010 | Weather King 10AJA3601AH Air Conditioner
I have a weatherking gas furnace that will not blow
Sounds like a bad blower relay. Check the voltage from the board or relay going to the blower for 110 volts. Replace the relay or board if no voltage.
Feb 07, 2010 | Heating & Cooling
KING FURNACE MANUAL
You do not need a warranty card for your warranty to be valid. Your installing contractor provides the labor warranty and the factory provides the warranty on parts. All the necessary information to make a (parts) warranty claim is embedded in the serial number of your unit. As for a manual you should contact the installing company or visit the Weatherking (Rheem) site to request this information. www.weatherking.com
Mar 26, 2009 | Weather King 12AJA4801AH Air Conditioner
Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Nov 30, 2008 | Weather King 12AJA4801AH Air Conditioner
I have an older weatherking furnace the inducer motor starts ,
My furnace did the same and I found a small crack in the hose going from the exaust fan to a presure switch. I cut the bad piece out and started working fine.
Nov 22, 2008 | Weather King 10AJA3601AH Air Conditioner
Finding the cooling contactor on weatherking acclaim II gas furna
the "y" terminal sends the hot leg of the 24 volts and the "c" terminal sends the common leg to the condenser..
Nov 15, 2008 | Weather King Heating & Cooling
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
