Question about Toshiba Portege M200 Tablet PC
I bought a used m200 from my sister. one day, i tried to start it and the power turns on but the hard drive doesn't start. i tried a different hard drive, but i get the same results. the screen turns on, but several colored lines show up after a few minutes. please help.
    Problem Solver:
  • 11 Answers
So you have bought a new Harddrive?, and still same problem, my guess would be that the pins inside the computer that read the hardrive are bent or broken. unfortunately but take it to a computer dealer to be sure
Posted on Jun 26, 2009
Charging battery
The battery may be failing.
Apr 11, 2014 | Toshiba Portege M200-S838 Tablet PC
Tip
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
Solution:
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
I want to know how to reinstall toshiba portege m200
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up.
Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot drive.select whatever drive represents your CD-ROM drive and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
Aug 01, 2011 | Toshiba Portege M200 Tablet PC
I ave a toshiba m200 that is taking to long to operate and when it does i stuck and refuse to function in any way!! i have no idea what is the problem and am trying to retrieve my work and upload it in a...
Hi,it is possible that the resultant cause the problem is your hard drive(caused by the hard disk failing to be READ from or be WRITTEN to,in this case be READ from),or one of your Memory modules is failing,so first of all try swapping or switching the RAM modules from one slot to the next,one at a time,if system is still slow,take out your hard disk,get a converter,slave hard disk to another system copy your files out and get a new Hard disk.
Jan 04, 2011 | Toshiba Portege M200 Tablet PC
When I turn in my toshiba tablet pc the toshiba logo comes on screem and there is a loud clicking but it never goes any further with start up. What could it be?
If the loud clicking noise is coming from the Laptop itself and not from the speaker, then it surely is a faulty hard drive. Try replacing it. Your alptop model will accept the IDE hard drives, just FYI.
May 29, 2010 | Toshiba Portege M200-S838 Tablet PC
I would like to reformat my notebook, but I do not have any of my original disks toshiba portege m200
Get yourself an windows (xp etc) & disk install it,
download all the drivers HERE
put them on a "USB flash drive" or burn to CD..
and load all the drivers after you installed windows.
be as good as new.
is this the information you needed?..
if so pls rate :)
Apr 13, 2009 | Toshiba PORTEGE M200 TABLET PC
Don't know how to get rid of hard drive password on toshiba lapto
A hard drive password can only be removed by the person who knows the password because then it can be cleared thru the BIOS.
Otherwise the only other way around it is the buy a new hard drive so it doesn't have a password and you can then reinstall the operating system on the hard drive and then put the drivers on it and any other programs that you want on it.
Apr 07, 2009 | Toshiba Portege M200 Tablet PC
Portege m200 wont boot from cd or anything.
look at this page
http://blog.ryantadams.com/2008/02/01/how-to-boot-from-the-network-pxe-boot-with-tftp-and-windows-pe/
it works very good.
Mar 27, 2009 | Toshiba Portege M200 Tablet PC
Can I use my ATT air card with my Toshiba Portege M200 tablet pc?
I have owned several tablet PC's and all of them (including my most recent Toshiba) worked just fine with the existing wi-fi card. Please be clear, however, that AT&T wireless air card service and "wi-fi" are two different things.
Your AT&T card pulls internet service over cellular connections, and your wi-fi card connects to a local hot spot (if available) or your own wireless internet access.
First of all, be sure that you have an active AT&T laptop connect account and then follow these steps:
Power on your laptop. Insert the AT&T wireless air card into an available USB slot. Wait a few moments (this may take several minutes some times), and the card will typically start attempting to install itself and its software. If you have any trouble with this, ATT provides free installation tech-support at the following site:
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/modem-cards.jsp
You may also have them contact you at your convenience by going to this page and filling out the form:
https://www.wireless.att.com/businesscenter/b2b/contact_us.jsp?wtLinkName=ContactATT&wtLinkLoc=RN
Hope this helps!
Jeff
Mar 11, 2009 | Toshiba PORTEGE M200 TABLET PC
Will a Bamboo Pen work on a Toshiba tablet pc M200
^The question is NOT asking about a USB thumb drive, and a lot of people seem to have failed to understand this.
This is a comprehensive forum thread regarding digitizers that work with Penenabled Tablet PCs: http://forum.tabletpcreview.com/showthread.php?t=12695
I don't believe Bamboo pens work.
Dec 26, 2008 | Toshiba Portege M200 Tablet PC
Toshiba Portege M200 Tablet PC Logo
130 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
