I run Windows XP Professional. Today there showed up a second layer of taskbar. It has ''Desktop'' in light blue, ''My Documents'' ''My computer'' and ''My Network Places'' shown in white with icons. Unable to click on right arrows to hide them. On right under the time is listed the day of week and the numerial month-day-year. Unable to drag these items anywhere or otherwise delete or hide this extra layer of bar. Looked within Task Bar options in ''My Computer'' clicking ''horizontal'' without any change.
You have only increased your taskbar size, don't worry...
Right-click on an empty part of the taskbar, and ensure the "lock the taskbar" is unchecked.
Next, position your mouse right on the top edge of the taskbar, your mouse should change to two black opposing pointing arrows. Hold left-click, and drag the taskbar down.
This will reduce the taskbar back to the way you're used to.
Hope this helps, and please rate this answer.
What is the best NAS for about $300 (+, - $100)? I was looking at...
(More)
What is the best NAS for about $300 (+, - $100)? I was looking at http://www.bhphotovideo.com/c/product/629822-REG/Buffalo_LS_XH2_0TL_2TB_LinkStation_Pro_LS_XHL.html,I need 2 TB of space, about 40 MegaBytesPerSecond, bittorrent, dlna , and web (configuration) access.
The clientpro 385 was recently restarted and now the power button flashes green every one to two...
(More)
The clientpro 385 was recently restarted and now the power button flashes green every one to two seconds. Unplugging the computer and plugging it back in changes nothing.
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the...
(More)
3 contact Led Switch 12 volts Question the Ground tab on Switch which needs to be grounded for the LED Toggle to light up, can this ground be connected to one of the computer 4 pin Molex Black wire. If so which one the Black Wire next to the Red Wire or the Yellow Wire.
tower switch dose not turn on.i took out power wire from the wall plug when i went to trip 5 weeks...
(More)
tower switch dose not turn on.i took out power wire from the wall plug when i went to trip 5 weeks ago
