Question about Canon Cameras
Have a canon a430 that has lens problems sometime does not close hold it up to a bright lite it will close .sometimes it does not focus a brite lite will start it focusing
  • larry stevenson Jun 26, 2009
    thanks for the help ,not sure if it will keep working but sofar so good thanksagain larry
  • 555 Answers
Hello my friend regarding on your problem there could be many things wrong with this. I really would say that the best idea is to send it back to canon if it is under warranty or being it to a camera service shop if the warranty has expired. I would many to suggest anything that would possibly damage the camera more or void your warranty. But if you decided to fix it by your self then you can visit this link i provided you. This link demonstrating on how to open your camera without destroying of damaging the parts of your camera. Kindly click this link: Fix cannon A430 this link has similar problem with your camera bout lens. So after you can open your camera you can clean and check the parts of your camera that might be the possibilities of making your camera not fully functional. Kindly check the lens connection if it is properly connected or the censors and also you can try and test your camera by turning it on and observe if their something not good activity going on in your camera inside.
But i strongly suggest/recommend that to prevent your camera from damaging further, please find a camera service shop in your place to fix it for you or you can return it to your supplier to fix and maybe replace new one.
Hope this suggestion/Recommendation or solution helps answer your proble/concern regading on your problem. If you need more assistance just reply to this post or contact me as soon as possbile and i am very much willing and eager to provide your with answers that helps your problem as best as i can.  If you find this solution/Recommendation/Suggestion useful please rate this one.  Thank you and godbless my friend.
Posted on Jun 26, 2009
My canon powershot a430 has always given me beautiful pics! I love it. but now I can only take pics inside. when I take pictures outdoors they come out white. what can I do to fix this problem?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 30, 2010 | Canon PowerShot A430 Digital Camera
Comming too bright while talking photos
try fixing your brightness withing the menu
Jul 02, 2009 | Canon PowerShot A430 Digital Camera
Horizontal Lines throughout the images
What Canon technician told you that your camera did not have a CCD? You sure that he was from Canon? And also the cost of repair would likely be more than the latest A480. Also note that you can get an A470 for around $70 these days. But no this is likely not CCD failure and is more likely a stuck shutter.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note that the article says to set your camera to 15 second exposure. This is not possible with the A430. Instead set it to manual mode, turn the flash off, and go into a darkened room. Take your picture there. Open the door while the red and yellow lights are flashing. Now the possibility for success with this method is not that great so don't get your hopes up. But it's worth a try before shopping around for a new camera.
May 30, 2009 | Canon PowerShot A430 Digital Camera
Sigma 70-300 mm lens wont focus
I was focusing to close to the subject & too much glare from a church window.
Sep 26, 2008 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Image too bright plus the white lines
Hi!
I had a similar problem with my powershot A430 recently. I took it to a canon service center and they identified the problem as "shutter unit problem". My cam was under warranty so they fixed it for free and also replaced my lens (even though i didnt ask for it!). :-)
Take your cam to canon; they will fix it. All the best!
-Aashish.
Aug 04, 2008 | Canon PowerShot A430 Digital Camera
Sigma 28-300 3.5-6.3 won't focus
Did it ever work on this camera?
I have seen some Sigma lenses that are auto focus on canon film cameras but then when put on the digital they dont work right. If you have used it on this camera then make sure the lens is clean.sometimes dirt on the front wil make it try focusing on the dirt. Next try focusing in manual focus to make sure the focus is working. Then take the lens off and then put it back on and make sure it clicks into place.
Let me know if none of those things work. also make sure to try focus on something close and somthing far away.
let me know how it works,
Caleb
Jun 26, 2008 | Sigma 24-70mm F3.5-5.6 AF Zoom Lens
Image result over bright at day light
Same problem here with the A430 I contacted Canon tech support and it looks like I'm going to be buying a new camera because it's not worth the effort and money to get it fixed. Rest assured, the new camera will not be a Canon.
May 24, 2008 | Canon PowerShot A430 Digital Camera
Lens auto focus sometimes does not work.
First make sure contacts on lens are clean ( see enclosed pic #2 ) . If this does not solve the problem the ultrasonic motor may be faulty pic #1.( sometimes switching on but sometimes not , will have to be replaced , unless there is a bad connection between the motor and lens pc board )
Nov 26, 2007 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Cameras Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
