Question about Maytag Washing Machines
Agitator is locked up
The machine pumps and spins fine. The agitator does not move and cannot be moved. Belts are fine.
  • 6,784 Answers
HI, You will need to purchase an agitator replacement kit asap. the agitator components are damaged. The clutch should be replaced as well.
Posted on Jun 26, 2009
Maytag A512. Screeching noise smokes. Belts replaced, water pumps fine, spins. It does not agitate but the agitator is fine. Not stripped. What other problems? Transmission? parts to fix it?
The agitator shaft, not the agitator, is corroded and does not move freely.Smoke is the overheated belts, you need a transmission overhaul, boot seal and tub bearing as well as replacing the agitator shaft, again, NOT the agitator.
Jun 06, 2017 | Maytag Washing Machines
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Agitator not moving
Following are the main reasons for the agitator not to move.
Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the
washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing
machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and
is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears
out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a
genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found
in automotive belts.)
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks for contacting Fixya.
Oct 12, 2009 | Kenmore 22422 Top Load Washer
The tub wont spin anymore and it makes a clicking soundwhen it tries to spin.As a result the clothes always come out very damp.
Lid switch
Motor coupler
Belts
Agitator
Oct 12, 2009 | Maytag Legacy Series Top Load Washer
Washing Machine Shaft Wont Move
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine will not spin or agitate.
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Nov 30, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Trans will not disengage
either you have something stuck betwwen the two tubs(ie. a sock. ) preventing the tub from free spinning.or there is a clutch mounted on top of the transmission not engaging, as far the agitator not spinning correctly sounds liek the agitaor dawgs are stripped preventing proper agitaing(bottom of agitator works fine but upper portion free spins both ways without resistance?? correct??
Mar 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Nov 29, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Will Not Agitate!
try replacing the drive bell, which is underneath the agitator. take the agitator off and unscrew the drive bell. remove and replace. the drive bell is most likely stripped.
Mar 29, 2007 | GE WDSR2080D Top Load Washer
Washing Machines Logo
223 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
