Home | Dell | E173FP 17" LCD Monitor | Monitor screen comes on ...
Dell E173FP 17" LCD Monitor
Problem for Dell E173FP 17" LCD Monitor
Monitor screen comes on when computer is first
By b_york1957 on Jun 26, 2009
Monitor screen comes on when computer is first turned on but goes blank within a second. If I turn the monitor off and then on again the home screen appears but then goes blank again. What could be the problem?
Best Solution
posted on Jun 26, 2009
Very Helpful)
buddymc
Rank: Guru  Dell Expert Computer Hardware  Expert
Rating: 94%, 286 votes
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell E173FP 17" LCD Monitor
Questions and Unsolved Problems for Dell E173FP 17" LCD Monitor
Do you recommend Dell E173FP 17" LCD Monitor?
Answer
Answer
have dual monitors, but when moving stuff from primary to secondary screen i have to drag it from... (More)
Answer
monitor stuck in power save mode, says to use mouse or any button on key board, done this but still... (More)
Answer
cant get out of " warning going into power save mode"
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell E173FP 17" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
