Question about Linksys EtherFast 10/100 (epsx3/uk) Print Server
Linksys print server Model EPSX3
I have a HP 1100 printer hook to a LinkSys print server EPSX3. Printer will sometimes start putting out blank pages without anyone sending a page to the printer!! Do I need a firmware update and if so, where can I find this update and how do I install the firmware update?
Regards,
Terry
    Scholar:
  • 141 Answers
Firmware upgrade for your print server could fix your problem or kill your print server.
Try this first: SET UP A STANDARD TCP/IP port.
Set a static ip on the print server. Use that ip address to set up your STANDARD TCP/IP PORT. You can do this on the printers and faxes page.
Right click the default printer then click properties. You have to ADD A NEW PORT.
Good Day
Posted on Mar 15, 2008
What is the password of epsx3 emulator
Go to Linksys, customer services for answers to these questions. (now Cisco). The answer could be also printed on the device tags, labels, or other attachments.
May 10, 2014 | Linksys EPSX3 EtherFast 3-Port 10/100...
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
EtherFast Print Server manual
Other gurus might correct me, but I don't think this can easily be done. You are dealing with "parallel" data with the HP and "serial" data with the PC. If your HP has cards you can change, then conversion to serial data is relatively simple, otherwise...
Mar 29, 2010 | Linksys EtherFast 10/100 (epsx3/uk) Print...
Linksys Etherfast Printserver model no EPSX3 getting error Print Server Failed, can you tell me how to fix it or why it's happening?
HI,
You will need to check the settings of the print server.
are trying to run the set up disc of the print server.
You can try to install the print server manually.
Click Here for more information
Oct 06, 2009 | Linksys EtherFast PrintServer Print Server
Have a linksys router tring to get adlink print
Did the dlink print server come with an installation disk? If so, you probably need to run that. It will help you set up a virtual printer port that you can then choose when adding a printer. For seting up two printers, you'll have 2 different virtual printer ports. For example SCB77031_P1 and SCB77031_P2.
If you need more help, please let me know what model linksys router and dlink print server
Aug 23, 2009 | Linksys Computers & Internet
Printer offline help
if you have a dhcp server then as per your prob it might not be getting lease from the dhcp server put the manual ip and cheack it
Feb 12, 2008 | Linksys Wireless-G WRT54G Router
What brand of print server would be compatible with a linksys broadband router and the HP printer?
You asked for any advice. If you want to use a server, you must already have at least a home network set up (it could be wireless or hard-wired). Yes, stand-alone "print servers" are notorious for only supporting certain printers. If you don't know this before you buy, you may find yourself returning your print server to the store. However, instead of a standalone print server, have you considered setting up one of the computers in your network as a "print server"? That's the way it used to be done. That's the way my own network is set up. You would set up your multifunction printer as connected directly to one of the computers in your network. Enable "printer sharing" on that computer. Then do the following on all other computers in the network for which you desire access to the printer: Add a network printer. If asked for drivers, get them off the printer's installation CD.
Mar 30, 2007 | HP PSC 1410v All-in-One Printer
Linksys EtherFast 10/100 (epsx3/uk) Print Server Logo
630 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
