Question about GE Profile Prodigy WPSE4200A
On my GE Profile no matter what kind of wash cycle it is on: heavy,medium or light wash the adjitator jams. I will be washing perfectly then all the sudded it starts jaming. The lights dim as it is trying to run off and on. It will do this for a while then stop. Each time it tries the lights dim then it will click and try again then the lights dim again.
Any sugestions???
  • armbender1 Dec 13, 2007
    It is hard to say what the noise sounds like. But kachuck kachunk kachunk it keeps doing that until it quits and dranes the water. I was thinking a relay is week and wont hold the contact for the motor. But yes the motor could be week.
    It is wierd because it will work perfectly for quite a while maybe until the motor gets hot or warm then it jams up. It makes the kachunk kachunk noise pretty fast then stops.
  • 362 Answers
From the description it sounds like the motor might be getting weak or something is getting caught underneath does it make any funny noises. let me know
Posted on Dec 13, 2007
  • james kilgore
    james kilgore Dec 13, 2007
    the bearing might be shot also to check it you can look at them and see if they look like they are falling apart. and the other way you have to be kind of strong you have to try and lift the tub and and move it around and listen for a rattling noise that is a bad bearing.
  • james kilgore
    it also could be a bearing wiggle the tub while lifting it and listen for a rattling sound or a kinda of growl with a popping noise
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
How long does it take to complete a wash cycle
In a perfectly normal washer with decent incoming water pressure it should take 3-5 minutes to fill depending on water level size selected.
If what your experiencing is that your washer does fill yet it takes forever the problem is going to be with the water inlet valve.
Oct 04, 2011 | GE Profile WPRE6100G Top Load Washer
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
GE Profile WPRE6100G Top Load Washer My washer is 2 yrs old and has started to make a loud metalic banging noise during the wash cycle. It does not during the spin cycle. Doesn't seem to matter whether...
The "Metallic banging/clicking" sound you hear is the Shifter mechanism engaging or disengaging.
The drive system will engage at the start of the Agitate Cycle and disengage when the Agitate Cycle is complete. This occurs multiple times during the wash. GE claims this is a normal sound and should not be concerned about it. Check page 10 of your Operating Manual, if you do not have a manual, click on this link to download one
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 03, 2010 | GE Profile WPRE6100G Top Load Washer
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Adjitator won't work
if the adjitator and the spin cycles do not work the coupler between the motor and the transmission is at fault
May 23, 2010 | GE WJSR2070B Top Load Washer
Washer will not complete the wash cycle.
faulty cycle switch. Try moving the switch manually when it reaches spin mode. Watch the switch when it reaches this phase of the wash/spin cycle to see what is does. If it jams or resets itself it needs to be replaced
Dec 15, 2009 | GE WSRE5260D Top Load Washer
Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Sep 10, 2009 | GE Profile WPRE6150KWT Colossal Capacity...
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Washing Machines Logo
97 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
