Question about Microwave Ovens
Leaking Microwave door seal (between grated and back of door)
I have what looks to be a thin plastic seal on the inside of the door of my microwave oven (Whirlpool). It appears to have leaked and I'm getting an ugly film (build-up) between the seal and the perforated grate in the door window. The plastic seal looks like it will peel right off the existing door and I've purchased a repalcement plastic panel, bit doesn't have an ahesive surface. Is there a trick to replacing this panel?
    Problem Solver:
  • 8 Answers
I think that you can get the plastic wet, ie sponge, or lick.
Posted on Jun 26, 2009
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
GE space maker microwave jvm1350bw002. Handle broke off at the bottom. I am looking to find a replacement hand determine if I can replace and if so are there instructions on removal of the handle?
On all of the JVM series I have seen you have to open the door and look on the inside perimeter of the door. There is a sort of thin, sort of Plastic, choke seal that goes around the inside of the whole door. Toward the outer edge. You have to take a butter knife or a smallish screw driver to lightly pop that part out of the slot it is popped into. The screws for the door handle are under that choke seal. Work around the whole door until you get that part out, Get one piece to lift up then keep working artound the whole door until it comes out. Then set it aside somewhere safe as to not let it drop or fall to the floor as it can break. To reinstall the choke you just align it to the slot where it came from and then start pushing it back into place. It has little hooks on the edges and it will snap back into place
Oct 15, 2017 | GE Microwave Ovens
Is there a way to detect if the microwave is leaking radiation?
No! this could not be further from the truth, you can buy a microwave test card and check for leakage around the door seals, or take it to a service professional to do a quick test.
Mar 06, 2012 | General Electric Microwave Oven
I have a Cookworks Microwave Oven Model EM717CKL. I have noticed that while it is in use, quite a strong draught is coming from the hinge side of the door. I have searched to find out if this is normal...
It depends on the amount of leak as a higher amount is not acceptable as there can be radiation leak. Please check the hinges and the door seals as there must be minimum gap to the chamber and door.
A small amount of the food flavors can be smelled while the microwave heats as this is normal. The door protect from any microwave leaking to the front and should not be a concern unless you are able to measure any stray radiation.
Mar 16, 2011 | Microwave Ovens
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
The plastic door handle on our GE Spacemaker XL microwave oven (JVM1341WW 002) broke. I ordered and now have replacement handle and screws onhand. How do I gain access to inside of the door to replace...
I do not know your unit specifically but a lot of them you have to start by, slowly, from the inside of the door, lifting up on the choke that runs along the outer inside edge of the door. It looks like a plastic trim part about 3/4 of an inch wide. You slowly work around the whole door unit you get it popped out. a butter knife or steak knife works pretty well . I just use a small flat head screw driver The screws for the handle are behind that choke seal. Usually 2 Phillips head screws. The choke part just snaps in place and has no screws to put it back, just push back in place and you will hear it snap as you go. Be careful the plastic tabs are easy to break off
Aug 19, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove/replace the plastic seal on the inside door of a MH1150XMQ-1?
The clear plastic cover is glued on. It can be removed with a heat gun to soften the glue. Then clean with Goof Off or WD40 and alcohol before installing the new one.
Eric
Jul 23, 2010 | Whirlpool MH1150XMQ Microwave Oven
How can i tell if microwave is leaking
The only way to tell for sure is to use a microwave leakage tester, which is an electronic instrument calibrated to standards for an accurate measurement. They are fairly expensive, so you aren't likely to run out and buy one. If you have reason to think your oven is leaking, you should call for service or take the oven in to a shop where they should have a tester.
Unless something has happened to damage the door sealing surfaces, your oven should not be leaking microwave. Check that the inside of the door and edges of the cooking cavity are kept clean of built-up food. Look at the door when it's closed. If it's straight side-to-side and is closing properly all around there should be no problem.
Do not believe the claim that you can test for leakage by calling a cell phone placed in the oven, and if the phone rings the oven is leaking microwaves. The shielding in a microwave is not effective at cell phone frequencies, which are much lower than microwaves. The phone will ring normally even in an oven with no measured leakage.
Feb 11, 2010 | Whirlpool GH4155XP Microwave Oven
IN CABINET MICROWAVE
Hello JudyKitz,
That mesh is there to protect the user and acts as a shield to contain microwave energy to the cooking compartment. Never compromise that material.. You can purchase replacment liners at this site http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130353 If you prefer, you can get a thin piece or sheet plastic cut to fit at many local hardware stores or home centers..You may want to make a paper template or take accurate measurements with you for that method.. Hope this helps you..
Oct 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Worried mother
MOM! When you say" Front Panel Door Seperates". Do you mean the front PLASTIC escuteon, or door cover? There is no seal as such like a gasket. The metal shield,or screen that you look through into your microwave is the seal. A microwave,( if it could be seen) is about the diameter of a pencil. It is neither gas, or liquid thus it cannot squeeze through openings smaller than it's diameter. So! the small openings or holes (That you look through) in the front screen of your microwave door are seen as solid metal by a microwave and the microwave is reflected back into the cavity. The only safety issue is damage to the screen.
Dec 05, 2007 | LG LMV1650ST Microwave Oven
Microwave Ovens Logo
352 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
