Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My door opens with the remote no problem however, it does not close and light seems to flicker on and off
    President:
  • 1,723 Answers
Take a look at the back of the unit and you will see a small yellow LED light. It will blink a certain number of times, which will indicate the fault it has acknowledged. Count the number of blinks, then look at the owners manual for the fault code in the troubleshooting section of the manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jun 27, 2009
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Guardian garage door opener not working,when I press the remote handheld button,the light in motor unit starts flickering. untill I press one of the 4 small switches,then it stops flickering. garage door...
Is your door jammed or could the door be moved smoothly? If not then the motor might not be able to start and it flickers, try to press "+" for open or close (depends on whether the unit is going to close or open the door) once at a time and try to remote it, this will increase the open/close force and may overcome the issue.One more thing, do the photo-eye sensors give unobstructed with good indication?
Jan 20, 2011 | Kitchen Ranges
The remotes opens the door when we leave. The remote will not close the door. Only the wall button will close-we have to hold it down until it is fully closed. Craftsman 1/2 horse 41A5021-3H
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to work you have a bad sensor.
Jan 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener opens with remote but will not close with remote. will open with wall button but button must be held down until door touches floor to close
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have a bad sensor.
Nov 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door programming a new remote now will open but will not close unless I hold wall bottom all the way to close. It does this now on all remotes? Any suggestions. Worked great until I tried to set in...
If the main lights flash 10 times when you try to close the door it is a door sensor problem. Make sure the sensors are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Nov 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
It is sears/craftsman K1026 139.53779 HBW 0709 . Button on the wall inside the garage will open, but does not close . it starts vibrating and the motor light flickering and no advancing. Only if you hold...
If the main light is flashing 10 times when you try to close the door it is a door sensor problem. Make sure the small light on each one is lit, not flickering and that one is not dimmer than the other. Tweak them a bit if necessary.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener from sears will not close the door from the outside. i have to go back in the house, close it with the button on the wall, then go back out. It does, however open the door when I...
If when you try to close the door with the remote it starts down and then the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Each of the sensors has a small light that should be lit and not flickering. Tweak the sensors a bit. If you cannot get both lights to come on you have bad sensors.
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remotes don't work, keyless entry won't work, wall remote some
Check to make sure the door sensors are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on then your sensors have failed.
Jul 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote opens door but will not close door (Liftmaster)
If when you try to close the door with the remote the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Usually it is because one of them has been bumped and is no longer pointed at the other one. If they are pointed properly they will each have a small light that is lit and not flickering. Tweak them a bit. If this doesn't work and the lights are not on you most likely have bad sensors.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
380 people viewed this question
Top liftmaster Electrical Supplies Experts
Mike
Gil Shultz
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
