Question about Magellan RoadMate 1400 Car GPS Receiver
Roadmate 1400 locks during boot upi believe the internal files are corrpted from firmware upgrade, can anyone share their files with me
  • rwwllms Jun 26, 2009
    I tried the reset button and it didn't work. Unfortunately I did not copy the files before the upgrade.
    Does anyone have the original files for the Roadmate 1400 they can send me?
    President:
  • 1,111 Answers
Try the hard reset, if you tried that,did you happen to copy your files off the 1400 before the upgrade?
Posted on Jun 26, 2009
I have a second hand 1400 that likes to fail booting once in a while, this time I thought I would jot it down so others would know and maybe I can find if I forget. Using power just got boot screen to come up then die out, USB same thing. I think my problem is not enough power left in battery to do anything with. 3 second and 15 second resets didn't work, so I set gps down with a pen lodged in the reset hole so it was always resetting, left it like that for well over 15 seconds and then after a while it worked fine. I did this because it seemed with reset button depressed power was cut off and maybe since I had the charger plugged in I was boosting the batteries enough to have a successful boot. It's flipping off and trying to reboot was probably a problem with not enough power in battery.
Posted on May 14, 2011
Unlock regional codes
try flash firmware with this file downloadable link:
http://www.firmwarehq.com/LG/GH24NS95/files.html
or this link:
http://www.lg.com/us/support-product/lg-GH24NS95
How to upgrade firmware
Only Windows support:
1. If you haven't already, download the firmware file and extract the zip
file.
2. Connect the drive to the secondary IDE channel as a master drive with
no other devices connected to that channel (Ignore if it's an SATA drive).
Start Windows and verify it can recognize the drive.
3. Close all other programs including: screen saver, and /or antivirus.
Do not open any programs or start any system functions during the
update as they can interfere with data transfer and damage the drive.
4. Open the firmware program RUN AS ADMINISTRATOR (right clock run as admin).
5. Click the update button and do not touch or interfere with the drive
while the firmware is being upgraded. IMPORTANT - DO NOT INTERFERE WITH
THE DRIVE DURING THIS PROCESS. If an error occurs during the upgrade
process, or the upgrade process is cancelled during this process, damage
to the drive can occur.
6. When the upgrade is complete the screen should say FIRMWARE UPDATE SUCCESSFUL. Re-boot your PC.
Nov 23, 2017 | Televison & Video
Magellan roadmate 800 update maps
http://www.peopleswireless.biz/magellan-rm800-traffic-kit.html
No You Will Need A traffic kit
Jul 05, 2008 | Magellan RoadMate 800 GPS Receiver
Roadmate 760 BSOD
A manual for your unit with troubleshooting guide can be found here.
May 14, 2008 | Magellan Roadmate 760 GPS Receiver
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
Can i upgrade my roadmate 1200 to include Portugal?
I also have a RoadMate 1200 and I wanted to update my map as well.
After extensive research (and periodically checking up on this every couple of months), I have found that the RoadMate series devices do not allow for any official map upgrades.
There have been reports of successful third party software installations on the RoadMate. Installing a third party software program (or "firmware") would completely change the menu on your GPS. It would be like installing Windows Vista on an iMAC. If it is possible to run an alternative firmware on the RoadMate, then it would be quite possible to download a usable map of Portugal. I have not seen any evidence of this yet. When I do I will let you know! :)
Also, an alternative firmware installation should only be done by an expert computer user. And an expert user knows that alternative firmware will void the warranty and that alternative firmware is VERY risky.
Sorry,
Steve
Jul 15, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Won't boot up and not recognised when connected to PC
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Jan 04, 2009 | Audio Players & Recorders
Laserjet 4250dtn Duplex problem
How is the printer connected.
Please upgrade the firmware of the printer.
Please upgrade the firmware of the printer:
1. Download the firmware file from the following website and extract it.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-13
Expecting that the printer is connected over the network:
Remote firmware update by using FTP through a browser
Complete the following steps to update the product firmware by using file transfer protocol (FTP) through a browser.
NOTE: The following instructions can be used on Windows or Macintosh operating systems.
Take note of the TCP/IP address on the EIO-Jetdirect page. The EIO-Jetdirect page is the second page of the configuration page printout.
Open a browser window.
In the address line of the browser, type ftp://<IPADDRESS>, where <IPADDRESS> is the TCP/IP address of the product. For example, if the TCP/IP address is 192.168.0.90, type FTP://192.168.0.90.
Locate the downloaded .RFU file for the product.
Drag and drop the .RFU file onto the PORT1 icon in the browser window.
NOTE: The product automatically restarts the firmware to activate the update. At the end of the update process, the Ready message appears on the control panel.
The following describes how to upgrade firmware in the LaserJet 2400, P3005 and 5200 Series Printers using a USB connection only.
To send the firmware upgrade via USB, you will need to know the name of the computer the printer is connected to, and the printer will need to be shared.
To find out the name of your computer:
Click the Start button, Programs, Accessories, System Tools, then choose System Information.
You will find your computer’s name in the right window-pane next to System Name.
Write down this name as it will be needed later.
To share the connected printer:
Click the Start button, Settings , then choose Printers ("Printers and Faxes" on WinXP).
Right click on the printer you need to send the upgrade to and then choose Sharing.
On WinXP, if you encounter the following link "If you understand the security risks but want to share printers without running the wizard, click here.", click the link.
Select "Just enable printer sharing" and click OK .
Select Shared As: ("Share this printer" on WinXP) and type a name for the share.
Click Apply and write down the share name as it will be needed later.
To send the firmware upgrade using a USB connection:
Go to a DOS Command Prompt and locate the directory where you saved the firmware file. (To open a Command Prompt inWindows 2000 or XP, go to the Start button, then choose run, then type CMD and hit Enter, in Windows 98 or ME, go to the Start button, Programs, Accessories, then choose MSDOS Prompt). This will bring up a small black screen as displayed below:
If connected to a USB port, Type: copy /b filename \computer nameshare name (for example, copy /b ozfw.rfu \computer1printer).
Press ENTER .
The control panel displays receiving upgrade followed by performing upgrade . The download may take several minutes.
The control panel displays processing job .
The download is complete when the printer reboots and "READY" message is displayed on the control panel.
Oct 20, 2008 | HP LaserJet 4250n Printer
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
Magellan Roadmate 700 firmware 3.32 upgrade
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it.i own now a mastreo 4000 so far so good no problems.
Feb 25, 2008 | Magellan RoadMate 700 GPS Receiver
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Magellan RoadMate 1400 Car GPS Receiver Logo
815 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
