Question about Garden
Craftsman 5.5 Gold mower will not start
I have a 5HP Craftsman Walk Behind Lawn Mower. I tried to start it after filling it up with gas but it is leaking gas from a hole in the rubber fuel primer button. Is this supposed to have a hole?Also it does not start.What am I doing wrong?Please help
  • 127 Answers
YOUR PROBLEM IS SIMPLE.
FIRST OF ALL THE HOLE IN THE PRIMER BUTTON MUST BE THERE TO POP BACK OUT EACH TIME YOU PRESS IT NOW AS TO THE GAS COMING OUT OF THERE
THE FLOAT IN THE CARB IS STUCK IN THE FILL POSITION AND WILL NOT LIFT ONCE THE BOWL IS FULL TO STOP THE GAS FROM FILLING OR YOU HAVE A PIN HOLE IN THE FLOAT ITSELF.UNDO THE NOT ON THE BOOTM OF THE BOWL WITH THE LAWN MOWER TILTED ON A 45 DEGREE ANGLE SEE IF YOU CAN MOVE THE FLOAT UP AND DOWN IF IT IS FREE MOVING SPRAY THE WHOLE AREA CLEAN WITH CARB CLEANER AND REASSEMBLE TRY TO START ,IF STILL THE SAME PROBLEM YOU WILL NEED TO REBUILD THE CARB AND INSTALL A NEW FLOAT
Posted on Jun 26, 2009
How do i take off the pull start from a craftsman model 917.377582 lawnmower
engine numbers would be helpful buttttt.... the perimeter of the recoil assy should be 3-5 small screws. remove them and it should come off, the is as long as you have a eagerbeaver engine ( tecumseh ohv )
Apr 15, 2015 | Sears Garden
How do I check the cut off switch?
If the oil is low, it will not start.
Jul 14, 2014 | Craftsman Garden
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
I'm looking for the manual for the Sears Craftsman II Lawn mower model # 917372850.
Gas-L0709214?brand_name_search=Walk+behind+lawnmower%2C+gas
Attach the above to the other sent link. It was too long to send together
Jul 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a carftsman walk behing mower with an eager1 egine
did you turn the mower upside down then the oil filled up the oil filter take off the filter then it should start it has to breath it takes mor air then fuel to make a engine run
Aug 30, 2009 | Craftsman Garden
Craftsman 5HP Mower does not start
try changing your primer bulb
May 31, 2009 | Craftsman Garden
Craftsman lawnmower carb pours gas
One of two problems. your needle and seat is leaking or the float has a hole in it
May 30, 2009 | Craftsman Garden
Garden Logo
758 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
