Question about GE Refrigerators
Gts22jbp ge does'nt get cold - GE Refrigerators
  • 351 Answers
Freezer ok i take it? if so is there frost on the back of the freezer? if so you have a defrost problem and ge is really good for defrost heating elements to go out... let me know
Posted on Jun 26, 2009
Have a GE Refrigerator Model GTS22JBP or GTL22JBP freezer works but frig wont stay cold
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit? CHECK
THERMISTORS ALSO
ALSO CHECK THE AIR FLOW VENT SYSTEM At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Aug 23, 2014 | GE Refrigerators
Why is my refrigerator not cooling?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. Refrigerator Defrost Parts
Jul 20, 2014 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
My ge gts22jbp has ice buildup temp was on 9 can this cause this or do i have a defrost problem
Defrost with hair dryer. If issue continues, then replace your thermostat control, Good Luck!!!
Apr 12, 2013 | Refrigerators
Frost in freezer
Apr 12, 2013 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Have ge gt mdl# gts22jbpbrww. the freezer is cold but the refrig is not getting cold. I took apart the cover showing me the freezer fan and it is not working could this be why the refrig is not getting...
Yes, if the fan is not forcing the cold air from the freezer section to the refrigerator section, then it will be warmer than it should be. Also check to make sure that the cooling tubes aren't blocked with frost/ice. If you put a hair dryer to the cooling tube openings you should feel the air flow on the other side.
Sep 06, 2011 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Ice maker not working and frig dosen't seem to stay cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | GE Refrigeration 21.8 Cu. Ft. Top-Freezer...
Ge model # tff34rvf refrigerator runs then shuts off for a long time. frezer makes ice and frezes items then things thaw agan
run times are to long . caused by dirty cond coil or fans running too slow . clean coil first this may correct problem . if not , the the cold control may be failing so replace it next .. and clean it reg . as it will nt cool when dirty .. mm
Jan 07, 2010 | Refrigerators
Refrigerator works fine except water draining into refrigerator from freezer in the back and the freezer has water collecting and freezing in the bottom of the freezer. There is no cube maker attached,...
You will need to remove the small cover on the top of the large piece mounted to the top of the freezer . There , you will see 2 screws which need to be removed . This will allow you to remove the large piece . The piece on the rear wall can now be slid up and removed . Remove the screws holding the rear panel and remove the panel . If you have an ice maker installed , it will need to be removed . Using a hair dryer , start defrosting about in the center , just below the coils , until you see the drain hole . Use hot water to help thaw the hole . Once water runs down the hole , use a small hose inserted into the drain , and blow out any unseen or built up debris in the drain line . Reassemble in reverse order .
Oct 06, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Refrigerator stops getting cold
you either have a defrost problem or your main control board is going out. When you opened the unit was the whole evap frozen or just the top by the fan if the whole evap. was then it is a defrost problem if nt the control board will have to be replaced part # WR55X10552
Apr 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Phone does´nt caller ID in Brazil
some countrys still dont have the call id upgrade you know example fiberoptics and with new phone its a win loose situation till they catch up
May 18, 2007 | GE 29267GE3 Corded Phone
Refrigerators Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
