Question about Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit
How to find a specific channel on Delphi remote
I can skip one channel ahead, but I cannot select one channel (e.g., 55) and go automatically to it
I realized you had to hit the buttong "pre/dir"which moves you back and forth between preset channels and direct channeling.
Posted on Jun 27, 2009
How do I remove channels ?
Select the channel you want to eliminate, select one by one, and skip them by pressing the skip button on the remote control. Skipped channels will not appear later.
Oct 18, 2014 | Sanyo DP19649 LCD TV
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Sep 09, 2007 | Zenith SY2751Y TV
Televison issues
There is nothing you can do, as this is how this set works. You will need to get a new set if you want the other stations.Good Luck.
Aug 30, 2007 | Philips Magnavox 13MT143S 13" TV
Delphi MyFi SA10113 XM Radio Receiver with Home and Car Kit Logo
85 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
