Question about Kenmore 62602 Electric Dryer
How to clean a dryer vent inside the machine
My dryer won't heat up. I am in the process of trying to clean my vents...I have checked the hose from the dry to the wall, now I want to clean the inside of the dryer. I am lost now. What do I unscrew take apart clean...ect. I am smart and can follow directions, but don't have any to follow...HELP PLEASE!
  • 351 Answers
Lift your lint screen up top see the two phillips screws? take them off then simply pop the top.... now look down on the left and right and you will see 2 5/16" screws take them out and there you be lift the door out....
Posted on Jun 26, 2009
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer takes long time to dry. usually 2 or 3 cycle. Filycter is cleaned after every cycle. Vent hose is not blocked
This complaint usually is attributed to clogged exhaust venting somewhere. As a process of elimination, remove the exhaust venting from behind the dryer and run your loads. If the dryer dries clothes properly, then your issue is definitely with the exhaust venting (e.g.: inside wall, attic, etc.). If possible, check the entire path of exhaust venting or contact a vent cleaning company.
Apr 14, 2010 | Whirlpool LEB6300 Electric Dryer
Taking long time to dry the clothes
Due to a dryer either heats or no heat , I would suggest pulling the dryer out and removing the vent hose . Dry a load of clothes to see if they dry normally . If they do , this verifys that the vent hose is either kinked ( restricting air flow ) , or , if the vent runs UP inside the wall , there is a restriction between the inside vent hose to the outside vent . May have to go into the attic to clean .
Jan 28, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is too hot and smell burn
Check the vent hase for kinks or clogs. I would suggest disconnecting the vent hose completely and run a cycle through the machine to see if it still gets real hot you may still get the smell because of the vent being inside if it doesn't over heat then I would inspect the vent hose or termination to see waht is stopping the machine from venting properly.
Jan 23, 2010 | Dryers
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
DRYER TAKES LONGER TO DRY
you could have restricted airflow from the lint screen not being cleaned, a bad blower wheel, or a bad thermostat. take the vent hose off the back and check to see if the air flows out the dryer with good force, if so your vent is probably clogged or not open in the wall. the vent hose may also be picned off from puching the dryer back to far.
Sep 17, 2009 | Whirlpool LER4634J Electric Dryer
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Kenmore 62602 Electric Dryer Logo
162 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
