Question about Optoma EP716 Multimedia Projector
EIKI XB23 PROJECTOR WON'T GO ON
When you turn it on the power light turns green then goes out and the warning light starts flashing. Have any ideas as to what the problem is.
  • barn7088 Jun 27, 2009
    well i took it down (it is installed on the ceiling) and checked the light bulb. I then checked it while it was down and it worked su back up it went and it quit working again took it back down and still not working. So I took the bulb out again and checked it put it back and now it works again. mI have not put it back up to see if it will keep working yet.
  • barn7088 Jun 28, 2009
    Ok yes there is more than enough air space. I checked the vents and the filters. The fan would start but the projector would only begin to start then turn off after maybe 2 or 3 sec. Since I took it down yesterday I have run it twice without a problem. It seems to be only when it is mounted upside down that there is a problem.
    Could it be a ballast? Yesterday before I took the bulb out again it would not run upside down on the table but it did not run right side up either. It was after I took out the bulb and replaced it that it worked but I still have not tried it upside down yet I will do that tomorrow and let you know what happens.
  • 54 Answers
Do you hear the fan start up? or does the projector lamp come on (you start to see an image)?
If yes to either:
When the temperature inside the projector reaches a
certain level, the projector will be automatically shut down
to protect the inside of the projector. The POWER indicator
is blinking while the projector is being cooled down. When
the projector has cooled down sufficiently (to its normal
operating temperature), it can be turned on again by
pressing the POWER ON-OFF button.
Note:
After the temperature inside the projector returns to normal, the
WARNING indicator still continues to blink. When the projector is
turned on again, the WARNING indicator stops blinking.
Then check the matters below:
– Did you provide appropriate space for the projector to be
ventilated? Check the installing condition to see if
ventilation slots are not blocked.
– Is the projector not installed near the ventilation duct of
air-conditioning equipment which may be hot? Install the
projector away from the ventilation duct of airconditioning
equipment.
– Are the air filters clean? Clean the air filters periodically. Let me know if you need to know how to do this.
If no to either:
When the projector detects an abnormal condition, it is
automatically shut down to protect the inside and the
WARNING indicator will be red. In this case, disconnect the
AC power cord and reconnect it, and then turn the projector
on once again for check. If the projector cannot be turned
on and the WARNING indicator emits a red light, disconnect
the AC power cord and contact the service station for check
and repair.
Please let me know if this helped solve the problem. If not, is there anything else you observed - whether or not you believe it's relevant.
EIKI XB23 PROJECTOR WON'T GO ON - 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Posted on Jun 26, 2009
  • Malcolm Montgomery
    Malcolm Montgomery Jun 27, 2009
    Interesting, but still not enough info to pin down. You didn't say whether you checked these, which could be helpful:
    equipment.
    Also:
    -Did you hear the fan start up? Can you tell whether it sounds the same as before the problem?
    -You might try running it upside down on the tabletop rather than installing it on the ceiling and see if that chaanges anything.
    Let me know.
2 Suggested Answers
  • 55 Answers
SOURCE: My data projector eiki LC-Xb23
If the power light & warning light both flash red, this indicates that the projector is overheating. Once the projector has cooled down the warning light would continue to flash red and the power light would be solid red.
You should clean the air filters.
The filters are located on the underside. Disconnect all cables and invert. remove the 2 air filters located at the front and rear by pullingthe latches. They are both rectangular in shape.
Being very careful not to damage them, you should rinse the dust out and leave them to dry fully before replacing them in the projector.
This should cure the problem.
Posted on Feb 17, 2011
Why won't my warning light turn off?
Probably a fan that doesn't rotate, or one of the many sub-voltages is absent on the mainboard due to short circuited capacitors ( SMD's)
Oct 25, 2012 | Eiki LC-SE10 Projector Multimedia...
Eiki LC-XB23 Projector vertical bands top to bottom of screen
almost sure 1 or more lcd panels are defective
sorry, but than it is end of life for this projector.
May 20, 2012 | Eiki LC-XB23 Projector
Need driver for LC-XB23
driver for what ? for rs 232 ?
Apr 07, 2012 | Eiki LC-XB23 Projector
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
My data projector eiki LC-Xb23 goes off without warning and the warning light is flashing
Feb 17, 2011 | Eiki LC-XB23 XGA LCD Projector Multimedia...
My projector doesn't stay on. what's wrong?
either the lamp cannot strike (meaning a ballast or lamp issue) or there the fans are not up to speed to sufficientl;y cool down the lamp and therefore shut down to avoid damage.
Feb 27, 2009 | Eiki LC-XB20 Projector Multimedia...
Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Dec 28, 2007 | Canon LV-S3 Multimedia Projector
Won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Jul 31, 2007 | Eiki LC-SB20 Projector Multimedia...
Optoma EP716 Multimedia Projector Logo
1,150 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
