Question about Kenmore Microwave Ovens
Microwave stops working f-7 code
Punch in what you want on keypad. turns on for 2 seconds. then shuts down and gives an f-7 code. kenmore elite ultra heat wave model number 665.63794300. digital read outs and lights work just won't run after the 2 seconds.....
The top quick access buttons stopped working 2 days ago. The bottom buttons still work but, we can't punch in a custom time. The only thing that will work is the 1 for 1 minute 2 for 2 minute...etc.
One of two things is happening, either you have broken connections in the membrane switches of the keypad and should replace the keypad(which is most likely) or your main control board has failed in a way that it can no longer read signals sent by the keypad.
Aug 04, 2013 | Microwave Ovens
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
F-9 pops up - microwave stops after 5 seconds. This is a Kenmore Elite Microwave, made in 2003. Model 721 63683300
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high .
WARNING : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please don't forget to rate !
Apr 04, 2010 | Kenmore Microwave Ovens
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore microwave (2 y/o) will stop soon after you hit start.
A quick test. Switch off power then remove outer cover. Look for the transformer. remove the two wires connected to the primary side. Note, do not toutch anything else. power still sitting on the cap. With those two thin wires disconnected, make sure they are not toutching each other or leaning on the metal frame. Set a program that has been a problem and let it run. If it still stops and does what its not supposed to do, your board needs replacement.
Sep 16, 2009 | Kenmore 80412 Microwave Oven
Kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Mar 01, 2008 | Kenmore 62622 Microwave Oven
GH7208XR Error Code #7
Behind the right front corner faceplate is a bag with the tech support info.
I used this and went through all the troubleshooting and got to the power inverter board. This board has the 2 red wires out of it that go to the magnetron. Instead of replacing the whole inverter module , I examined all the components on it. I found that there are 2 high voltage rectifier diodes attached to the transformer and 1 of them was not testing good. The diodes are UXC2B diodes.. Just clipped out the bad one and soldered in a new one.
Hope this helps..
Dec 21, 2007 | Whirlpool GH7208XR Convection / Microwave...
Error code of F-3.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
The microwave oven may be provided with a self diagnostic routine that can be operated through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed.
If you want to try to fix it your self, Always remember Electricity is dangerous and should be treated with respect.
Microwaves are very dangerous, they can still shock you even unplugged!!
Use a metal ( not the shiny chrome type ) screw driver with a insulated handle to short across ( touch both at the same time ) the terminals of the high voltage capacitor to discharge it. With the microwave unplugged.
If my attachment made it, it shows a common way to do this....
Good Luck!
Microwaves are very dangerous, they can still shock you even unplugged!! These pages are to help give you indications of what might be wrong and some safe "how to check" or repair help.
Oct 29, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
149 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
