Question about E-Machines T3612 PC Desktop
Network card I need a new network card and cannot find the type i need. If you know where i can go to get one i would really appricate it.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Are you looking for a wireless card or one where you can plug in a cable?
  • 434 Answers
Any PCI network card should work your machine. When you go to buy one, just look for PCI on the box and wireless if need be.
Posted on Jun 26, 2009
No connection to wifi
What OS are you using? Have you ever been able to log on to a wireless network? Is your network adapter ENABLED? Can you connect with your wired network adapter?
Aug 17, 2014 | Acer Black 15.6" Aspire E-Series...
Identify correct network card for dell xps 420
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Nov 29, 2012 | Dell Ethernet Card Network Adapter
I have a internet access coming into my house but the desktop pc is not recieving any internet signal but the other pcs on the network are. i have a message saying the lan card is not recieving any...
Yes, it could be or it needs to be removed and then re installed.
You can go into tcp/ip properties and see if you can uninstall the network card.
I am not sure be here remotely that the physical network card works or not.
If there isn't green light showing on the network card ( this will be on the back of the desktop) then it may be that you will need a new one but uninstalling it and physically removing it from the desktio and then reinserting it ( with the power off of course) and with the desktop shut down without the network card in the desktop 1st. Then re inserting the network card in the PCI slot and powering up the PC maybe all that it needs to reinstall it ( plug and play) that is.
Jun 29, 2010 | Packard Bell 1580509280 Network Adapter
Time warndr says slow connection caused by faulty network card. OEM card part of motherboard. What do I need to buy?
Your motherboard in this PC has two PCI cards, and one PCI express card. You may have one of these free to install an Ethernet card. If the PCI express slot is open, it is your first choice. The ethernet cards are labeled PCIe. There are many brands to choose from. Your system is using an Intel based LAN card.
Tiger Direct sells a PCIe Ethernet card for $49 made by DLink and a Trendnet PCI card for as little as 7.99. I have used both brands and they work well. The PCIe is faster.
Jan 14, 2010 | Dell Dimension 4700 PC Desktop
Dell Dimension 5100 Network Card Issue
my friend if it is not on board network card, un plug the card and replace with the new one and then u make sure that u follow the instructions given when installing and also u have to configure again the ip adress or net work set up as before
May 22, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Has An Acer Travelmate 243LC laptop got a build-in Wireless?
The link below will take you to a page on the Acer Web site that shows the specs for this laptop. According to the specs, this laptop does not come with onboard wireless (if this feature were part of the system, it would be listed in the specs). Also, you can check Device Manager to see if you have a Wireless Adapter listed under Network Adapters. If you don't see any type of Wireless adapter listed then you'll definitely know that your laptop doesn't have it built in.
To access Device Manager:
Right-click My Computer
Click Properties
Click Manage
In the left navigation pane, click Device Manager.
In the larger window, scroll down the list to Network Adapters.
Expand the Network Adapters tree to see the installed adapters.
http://www.acersupport.com/notebook/html/tm243lc_specs.html
However, the specs do show that this laptop has 2 PC Card slots. These slots give you at least a couple of options for connecting to the Internet. You can buy an Air Card that is installed in one of the PC Card slots when you want to use it to access the Internet. My company used to provide Air Cards for laptop users through AT&T. The advantage is that you have an uninterrupted connection to the Internet no matter your location.
You can also buy a WiFi card that fits into a PC Card slot. This card will be your Wireless NIC (adapter) providing you with the means to set up connections to wireless networks. Linksys is a pretty good brand and fairly easy to install and support. After installation and configuration, you can pop the card in your PC Card slot anytime you want to connect to a Wireless network then remove it when it's no longer needed.
I hope this helps you connect wirelessly using your laptop. Please rate this solution and thanks for using Fixya.
Mar 28, 2009 | Acer TravelMate 243LC Notebook
Network cable stopped being recognized
ati catalyst is for a graphics card.
it would not have issues.
the card may show as fine, or the drivers may. try the card in another pc. if it is built in try a new card. ethernet cards are just a few pounds.
Feb 25, 2009 | Computers & Internet
LAN PROBLEM i cant get internet connection? pls help me
Sounds like you are connected to a wired LAN. You need to make sure your network card is getting a signal. Check in control panel and see if you have a network connection. If you do have connection. You may just just need to reset your Internet settings to default and restart the computer. You also can do a repair of your network connection and see if this helps. Really need to know what type of network your tying to connect. It it a business or home Internet?
Feb 18, 2009 | Toshiba Satellite A105 Notebook
Network card
hi im wesley. ok well is your computer newish or older model if its a newer model you can just get a standard network card but if its old you mite not be able to get one its very rare to find olderones not mant pc shops sell them anymore otherwise you mite need to upgrade you pc
Jul 08, 2008 | Computers & Internet
E-Machines T3612 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
