Question about RCA HD52W58 52" TV
MY TV MODEL D52W20 WONT TURN ON,I PUSH THE ON BUTTON AND THE LITE FLASES 3 TIMES BUT WONT TURN ON
    Problem Solver:
  • 16 Answers
Look for capacitors in the front of the deflection board to be bulging at the top and leaking. Replace with new caps
Posted on Jun 26, 2009
My tv wont turn on when u push the power button no pic or volume comes on and the power button just blinks
Different possibilities:
1. Bad hv circuit (flyback)
2. Bad connections on flyback & the little fuse next to it
3. Bad fuse near tuner
4. Bad picture tube
This tv is known to have any of these problems.
Apr 28, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv wont turn on you push the button and it makes a lite squeal noise then the light will turn off and on 3 times the turns off
sqealing noise is a general syptom of a shorted horizontal output transistor and a bad flyback. it could be more but as a technician that the first thin i would check.
Oct 30, 2010 | RCA Televison & Video
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
52 in rca rear projection hdtv wont power up power light flases three times
3 capacitors on the deflection board cp150,cp114 cp120 2200uf 16v use 25v 220uf 35v cp 150 most of the time is puffed up on top.
Dec 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on. green lite for 4 secs, 3 times, then off. D52W20
It could be several issues from a bag power supply, the TV is connected to a power strip with several other components hooked up (DVD, Sound System, Xbox, etc.).
Try connecting to the wall directly and see if it now starts up.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't turn on
I have the same problem; I push the power button green light comes on tv clicks but doesn't come on.
Aug 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not turn on
Look on Deflection board 3 capacitors need replacing cp150---cp114----cp120 one is 2200uf 16v Two of them are 220uf 35v. Buy capacitors at Radio SHack. If cp150 is puffed up on top it is bad so replace other 2 caps as well.
Dec 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD52W58 52" TV Logo
328 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
