Question about Linksys WRT160N Wireless Router
Trouble setting up router
I PUT IN NTHE CD N FOLLOWED ALL THE INSTRUCTIONS BUT I KEEP GETTING AN ERROR MESSAGE "ETHERNET CABLE NOT CONNECTED CORRECTLY. HELPPPPPPPPPPPPPPP.
  • 24 Answers
Make sure it is not a cross-over cable, and unplug the Ethernet cord at both ends and then re-connect. Also try a different cord. If you are doing this wireless I would recommend you using an Ethernet cord. You could also push in the little reset button on the back of the router for 45 seconds and then unplug the router then plug it back in and start over with the CD.
Posted on Jun 26, 2009
I can hook my Toshiba laptop to the router by wire, but when I try to go wireless I get an error message. "Exception has been thrown be the target of an invocation" What should I do? I have a WRT110 Wireless Router Linksys.
Posted on Jul 05, 2009
I just purchased the D-Link wireless router. Connected everything ran the CD and I'm not connected for some reason? I may have connected something wrong, but I was following all the instructions...my error...
first of all for using a router you need not install any cd...
try connecting your laptop to any one of the wired (lan) ports of router using an ethernet cable and check whether you are able to access or not...
if you are able to access then search for the wireless networks in range...
you will see linksys network... try connecting to it and access wireless internet...
if you are not able to access internet even through ethernet cable then you need to configure your router first...
to get an idea of how to configure your router have a look at this link...
Jul 16, 2010 | D-Link Wireless
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
I keep getting an error message when i set my router up
The LAN cable maybe faulty, try a different LAN cable.
Jan 04, 2010 | Linksys WRT120N Router
Everytime i set up my router it says "your ethernet cable does not appear to be connected properly. Error 321: Ethernet Cable not connected" now i have tried setting this up multiple times but i keep...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Un able to secure my wireless connection
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Dec 15, 2009 | Linksys WRT160N Wireless Router
Having problem installin the WRT160N. The cables
You can actually configure your router manually without needing the Setup CD.
You may refer to this link for setting up your router for Cable.
And refer to this link for setting up your router for DSL.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Problems hooking up a Linksys wireless router
Please disconnect the USB cable that connected from the modem going to your PC. Now connect the ethernet from your cable modem to the Internet port of your router. Run the setup CD, that should guide you and will make you up and running connected to the router.
Nov 20, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT160N Wireless Router  Logo
310 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
