Question about GE GSS25LGM Side by Side Refrigerator
How do I remove the ice maker from GE side by side freezer?
GE GSS25LS side by side. I have removed the 1/4 screws and the unit does not come out. Is there another connector?
    President:
  • 1,136 Answers
Hi, It looks like there should be 3 screws. Is it possible that there is ice built up behind it to hold it in place?
If the ice maker is sitting on a plate, check and see if there are screws in the bottom of the ice maker.
Vic
Posted on Jun 26, 2009
Ge Gsh25jsxnss side x side fridge is not getting cold, took plate off & damper works fine, I don't see ne kind of fan, it goes straight 2 the freezer near the ice maker. freezer is cold & working fine
Evaporator fan motor has probably failed. p/n WR60X10185
It is located in the freezer section, behind the back panels inside, and under the icemaker. Remove the screws on the bottom panel in the freezer, remove the ice maker, auger motor, and panel. is is about center of the freezer.
Jun 22, 2016 | GE Refrigerators
How to remove ice maker on ge profile pfss6pkwbss
You would first have to distinguish between if the tray has a crack in it or if the water valve is not closeing which would mean you would need a new water valve. Most all ice makers are held to the freezer wall by 3 1/4" screws you would unscrew these screws and unplug the power connector and remove the ice maker from the unit. Fill the ice tray with water and see if you do have a crack in the tray which is not as common as a water valve allowing to much water to go into the ice tray makeing it overflow. If you have any further questions message me back I await your reply.
Thank you,
Rick
Jan 19, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Hi, we just purchased an 5 year old GE profile refrigerator with full door/bottom freezer from a private party. It was working fine at his house. The refrigerator has a loud buzzing every 1/2 for a few...
The buzz is most likely coming from the water valve that feeds the ice maker. If the ice maker is not being used the buzz will continue unless the power is disconnected to the valve. It does not hurt anything but can be annoying.
If the ice maker does not have the shut off handle (arm) to lift then a solution would be to unplug the ice maker itself. If you look at the ice maker in the freezer it is usually held on by 3 screws to the side wall. If you remove these screws there will be a wire plug that you can unplug and remove the entire ice maker and free up room. With it disconnected the buzz will stop.
Apr 18, 2010 | GE Profile Stainless Bottom-Freezer...
Water overflowing in ice maker tray on a GE
make sure your refrigerator unit is level first . If it is , and you have eight square faced plastic cover on the front of the ice maker itself that can be removed by un- snapping it, remove it and see if there is a small screw with a spring underneath it or positive or negative arrow's on the unit where the screw is located. Regardless, if there is a screw all by itself turned the screw 1/2 turn Counterclockwise. this will decrease the amount of time the water valve is open during the ice bin filling cycle.
Mar 13, 2010 | GE Monogram® ZISS420DMSS Side by Side...
Replacing Defrost Heater and Bracket in Freezer Section of Fridge
I ended up having to remove things in this order: all shelves, ice maker insert, ice maker top ice tray, ice maker lower motor housing, shelving support rails (2), rear evaporator coil cover. This exposed the evaporator coils (which were already dry since the fridge had been off for two days) and most importantly, the defrost heater element below the coils. The heater element was easily unplugged from it's two connectors. I tested the unit with an ohm meter and it indicated it was open (infinity resistance). I then knew it was bad. I replaced it with a new unit and put everything back together in reverse order taking care to use the same screws. The fridge appears to be back in working order.
Oct 18, 2009 | GE Refrigerators
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Jul 23, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Replacing the ice maker mechanism on a GE side by side
  1. Unplug the refrigerator.
  2. Remove the icemaker's front cover by unscrewing or prying it off as needed
  3. Remove the ice bin, shelves, and vertical partition.
  4. Remove remaining screws, disconnect the icemaker wires from the harness connector or socket, and remove the unit from the freezer.
  5. Remove the back access panel and any fasteners that hold the inlet valve to the refrigerator.
Jul 06, 2008 | GE GSS25SGMBS Side by Side Refrigerator
I would like to remove the ice maker from my freezer.
REMOVE THE 2 MOUNTING SCREWS ABOVE THE ICE MAKE,REMOVE THE 1 SCREW UNDER THE ICE MAKER,DISCONNECT THE ICEMAKER JACK AND YOUR DONE,YOU NEED DO NOTHING ELSE,HOPE THIS HELPS,THANKS-MIKE
May 31, 2008 | GE Hotpoint Top-Freezer Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
228 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
