Question about HP Pavilion MX70 17" CRT Monitor
Computer flashes on tv for 1/2 second then goes away using s-video hp vista
  • 478 Answers
If you are loading up on the monitor first then switching over to s video that would be the problem you must load up in s video and the monitor unpluged
Posted on Jun 26, 2009
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Hi I have a problem of black screen with my hp pavilion dv400. Wheen I start my computer I can windows logo on the screen but just 1 or 2 second and the screen go black. But when I connect my computer...
Your laptop is probably outputting the video signal to the wrong monitor. When the screen goes black, try pressing the function key to switch the video back to the laptop screen. Refer to your laptop's manual on what key to press. Usually it is the Fn key and F4 at the same time for HP laptops.
Jul 06, 2011 | HP Pavilion dv4000 Notebook
My PMP352-4 will not connect to my computer via the USB inlet. It shows up as a removable disk for about 3 seconds then drops out. the safety removal program flashes and then goes away as well. How do i...
Apparently you are not the only one. this has been an issue with Vista. redownload SP1 for Vista
My computer is not detecting the MP3 Player with Windows VistaThere is a USB mass storage devices recognition issue with Windows Vista acknowledged by Microsoft. A solution is available in the
Service Pack 1 which may be downloaded from Microsoft's website
I hope this helps
Thanks
Please rate FIXYA
Apr 06, 2011 | Polaroid Audio Players & Recorders
Connect tv to computer
Be sure to enable the second screen through the windows display settings. Right click on the desktop background and select personalize (VIsta) or Properties (XP). Click on the settings menu (lower down on Vista, a tab on the right for XP) and look at the monitor setup. After you are connected via cable to the TV, go there, click on the second screen and select "enable this monitor", "extend desktop onto this monitor" or something of the like. Oftentimes it will not do it if you are not already physically plugged in so ensure that you do that first.
Aug 26, 2009 | HP Pavilion Elite M9150F Desktop PC
When i plug laptop to tv, only desktop shows, no icons, nothing.
You have to go to "Display" properties... (right click on desktop and go to properties)
on one of the tabs that comes up you should see 2 boxes one with a number ONE in one box and a number TWO in ther other. Right-click on the TWO box and click ATTACHED.
Then click and highlight the TWO box and underneath the two boxes there should be a checkbox that says "Extend my desktop to this monitor" and then hit APPLY.
If you have any issues with how its being displayed on your TV you'll have to adjust the size of the ONE and TWO boxes to be of equal resolutions.
(if FN+F4 doesn't work to get your desktop back, Try FN+F5 or the key on you laptop with the monitor icon)
Hope this helps!
May 30, 2009 | HP Pavilion dv2500t Notebook
My hp w2207h goes to sleep
Turn off the "powersaver" feature on your monitor by pressing <menu> then <management>then <powersaver> select off.
Nov 20, 2008 | HP f2105 21" LCD Monitor
TV Flashed HDMI
check samsung web site for firmware upgrade, or use component cabling, which is HD also
Jul 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Monitor goes blank less than a second after turning on.
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
HP Pavilion MX70 17" CRT Monitor Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
