SOURCE: Whirlpool Wall Oven sometimes power
Could be several things; 1. Electrical connections in oven are loose. 2.The circuit breaker for the oven could be failing. 3. The electronic control is failing. Make sure when oven is operating, the cooling fan is operating. If the cooling fan is not working, the electronic control will overheat and shut down.
SOURCE: power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
SOURCE: I HAVE A NEW WIRLPOOL OVEN, AND KEEP GETTING ?PF?
the next thing for you to check is your main power circuit breaker if you have one side of the breaker is bad or weak this will cause a power failure.also make sure the wiring to the terminal block is in good order and not damaged.the terminal block could have a problem as well.
