Question about SanDisk Memory Media
Cannot access and Format SanDisk 512MB memory Stick PRO Duo
Hi, i use SanDisk 512MB memory Stick PRO Duo. It somehow got corrupted. I tried to formattin in DOS , Disk mgmt, n even with some supporting software used 2 recover gfiles n 2 format drives.whenever i try 2 format r access it "NO DIsk Window " pops up.Can ny1 help me out.. thanks in advance. regards bks.
    Genius:
  • 1,234 Answers
Hi sir
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Posted on Aug 28, 2010
When i formated the Memory Stick pro duo computer stopped and was not complete formatting Stick Pro Duo now not working What can I do?
Hi!
There are 50% chances to make it work again.
It may need a so called low level format. A great tool for low level formatting is from HDD GURU,
please google for hdd guru low level format and download the software. It is very easy to use, but please be very carefully when you choose the drive letter to be formatted, because otherwise it can format even the system disk. If this tool does not detect the card, it is almost sure broken for ever and it need to be replaced.
Hope it helped,
Bogdan
Sep 25, 2011 | SanDisk 2GB Memory Stick PRO Duo Memory...
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    How do i format my sandisk 8gb m2 memory card to work with my sony ericsson w395as it doesnt seem 2 work when its in the fone ive tried formating it on my pc but must be different settings for the fone
    hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
    Mar 18, 2010 | SanDisk 4GB Memory Stick Micro M2 Memory...
    SanDisk memory stick pro duo 4GB not reading
    does ur camera recognize ur mem stick if yes then copy all ur pics to a computer then format it an insert the stick to ur cam and u can copu it again to the stick. check it out.
    Oct 13, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
    My phone is not detecting the memory stick micro
    Format the memory card in pc or any other phone then insert in your phone it will work.
    Aug 11, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Sandisk 2gb memory stick pro duo wont format
    it means it is containing some virus...try to format it with some other system..but it is a frequent problem...try to delete the files while in the phone and format using the computer...its better to claim warranty if it has....
    is this cleared your problem?
    Jul 15, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
    Actually, I am having this problem with 2 memory cards that i have been using for a while. All of a sudden I cant access the pics. It wont autorun, and when I try to go directly to the drive I get the...
    The possible cause of issue is file corruption or virus infection, scan your MMC cards for any virus infection or format it using the device in which you use it.
    Jul 02, 2009 | SanDisk 4GB Memory Stick PRO Duo Memory...
    128mb Sony Memory Stick Duo
                This is a common problem and its quite easy to resolve.
    I had a very similar problem with a friends nokia 5200 memory stick , it refused access to the card , i got the message disk is write protected I couldnt even access it from a PC card reader or format it .
                 Somehow he had accidentally set a security code for the memory stick and the mobile then forgot he had done it , I tried the usual code of 1,2,3,4 and this didnt work.
        When I tried the number 1 on its own , suddenly I could access the memory stick again and format it and didnt get the message (disk is write protected)...Reset your P800 security codes with the master reset function in the main settings menu.This will remove any codes that restrict access to the memory stick...
    Sep 03, 2008 | Sony Ericsson Walkman W810i Cellular Phone
    Sony 512mb Memory Stick
    You will see the removable drive in my computer...(Mcard)
    > rightclick that > format > tick the "quick format" > and format
    May 27, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
    SanDisk Memory Stick Pro Duo
    Try a couple of these trial downloads, to see if the pics are recoverable, but it's possible that the psp formatted it to it's own file format. http://www.cardrecovery.com/?rid=google&kid=cr0119 http://www.freedownloadmanager.org/downloads/memory_stick_recovery_software/
    Mar 23, 2007 | SanDisk Memory Media
    Electronics - Others Logo
    164 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Carlos Calvo
    Level 1 Expert
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
