Kitchen Ranges
Problem for Kitchen Ranges
Generic problem for all Kitchen Ranges
Broiler works but oven won't heat up
By jrentals on Jun 26, 2009
Best Solution
posted on Jun 26, 2009
Very Helpful)
jsrock516
Rank: Guru
Rating: 96%, 6955 votes
If you are having problems with the bake feature not lighting or taking longer than usual to ignite, you may have an oven igniter going bad. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If your broil feature still works, you probably don't have a gas problem. The gas for both oven manifolds is fed through the same source. Barring a problem with the oven control board, you more than likely have an ignitor on the bake manifold failing or has become weak. The bake feature tends to fail more often due to the frequency of use.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
Maytag317
Rank: Guru
Rating: 93%, 663 votes
Hi, If this is an electric oven, check the bake element for continuity to see if it is bad.
If this is a gas oven, change the ignitor. The ignitor is a very common problem with the gas ovens.
I hope this helps
Please let me know if I can assist you further.
Vic
Was this helpful?
Yes
No
Popular Solutions for Kitchen Ranges
Questions and Unsolved Problems for Kitchen Ranges
Answer
Is the Dynasty DGRSC304SSB a good range and is $2200 a good price?
Answer
is the maytag range mer7775ww a good buy?What are the complaints about it?
Answer
My ESS602 Delonghi main oven won't heat up. The fan comes on but there is no heat. Could it be the... (More)
Answer
I moved into a house with a Spectra electric range and there was no manual for it.
Answer
My stovetop takes about 45 minutes to boil a pot of water. All eyes do the same thing. The oven... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Kitchen Ranges Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
