Question about A D S HARDWARE, MINI DUAL TV TUNER PTV339 Plus $25 off w/ eBillme (0757887339203) Video Capture
My pc camera is saying that no video capture is found
How to solve wen it tells no video capture found
Posted on Dec 01, 2009
How do I attach it to the computer so that it will be found as a capture device? I am trying to use MoviePlus X3. When I click on capture, it says no capture device found. I am assuming I do not have the...
>I am assuming I do not have the camera hooked up to the computer properly....
Correct.
An analogue camera will require an A/D Converter in between the two.
Many mini DV Cameras can act as the A/D Converter if they have audio & video inputs.
The 8mm camera connects to the Converter with analogue cables and the converter connects to the computer with a firewire cable.
Feb 12, 2011 | Hitachi VME510A 8mm Analog Camcorder
The video from my digital camera is not being captured. Says no capture driver is available
Digitasl camera movies are stored formatted already you just need to copy the movie to your PC and open the movie for editting, or use your camera software to save the movie to your PC.
Aug 25, 2009 | Ulead DVD MovieFactory for PC
Camera cannot find video capture filter
i found out that in the "devices" option i checked" webcam basic" instead of "I catch (VI)PC camera"
Feb 14, 2009 | Philips J44414
Sony analogue Hi8 Handycam as a security camera
Hi!
You need to have things with you before you can proceed to use it as a security camera. As your's is a analog camera we will require a video capture card connected with your pc/laptop.
After you have one connect that with your pc and pTo get the video into your computer, you need a analogue to digital video capture card....otherwise, connect the camcorder to a CD or DVD player/recorder, and use the CD/DVD as a source for your video editing... Otherwise, you need a later model of SONY "Digital 8" digital camcorder which plays analogue tape, and with this your computer can capture the video via firewire
For details on how to record using a software and video capture card please look at this link---
Handycam as Security camera
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 06, 2009 | Sony Handycam CCD-TRV68 Camcorder
How can i download better quality video from mini dv to pc
You do need a good capture card if you want the best quality. However these tend to be a bit expensive and I have found that if you have a DVD recorder with an i-link input, then copying to the recorder will give you excellent results. After you have made the recording, you can then edit it very easily with say DVD shrink on your PC.
It may even be cheaper to buy a DVD recorder with i-link features than having to buy a capture card!
cheers
Nov 11, 2008 | Sony DCR-HC54E Mini DV Camcorder
Easycap
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
Sep 04, 2008 | Ulead Videostudio 8 for PC
Connecting Camcorder to PC
Windows Movie Maker won't detect the camera but Video Edit Magic should.
Aug 29, 2008 | Sony Handycam DCR-PC110E Mini DV Digital...
Problem in video capturing through firewire
Hi Sreeki,
You may have solved this problem already but I had the same problem some time ago, so the advice will be a little vague.
From memory the issue is something to do with corruption of a directx file so you could just try re-loading directx.
But the way I found a solution was to try and capture video using windows movie maker and you will find the video capture also fails using this software. However, windows returns an error message (which I cannot remember), and I did a search on Google or something for this error message and eventually found the solution.
It was related to directx and there was a small file that had to be run to repair it.
Hope this helps and I will continue searching for the problem I am now having with my camera not accepting a tape and returning the error message relating moisture......
Mar 29, 2008 | Sony Dvcam DCR-HC15E Mini DV Digital...
Video capturing
You might need a specific driver for this camera. Do you know if you've installed a driver specific for this camera?
Sep 09, 2006 | Ulead Videostudio 8 for PC
Can't use my Sony TRV22 miniDV camcorder to pass through and record Hi8 analog signal to my PC
Just below, they noted you don't put a tape in the TRV... Otherwise it outsmarts you.
Sep 13, 2005 | Sony Handycam DCR-TRV22 Mini DV Digital...
A D S HARDWARE, MINI DUAL TV TUNER PTV339 Plus $25 off w/ eBillme (0757887339203) Video Capture Logo
260 people viewed this question
Top A D S Televison & Video Experts
Marvin
Marvin
Are you an A D S Televison and Video Expert? Answer questions, earn points and help others
