Question about Acer Windows Vista TL-562G Notebook
Use Incoming Wireless to Send Out Ethernet *Internet Sharing*
I have a Wireless Incoming Connection... I want to send that out of my Ethernet Port to another computer.
I have done so, with limited success, but looking for the best and simplist way of doing so..
I also have a Wireless Linksys WRT54G Router, with no Cable Modem attached... and if you know how to convert that to transmit my incoming connection, please let me know...
But if only, I would love to know how to take my Wireless In, and Send Out Ethernet to another computer.
  • 3 more comments
  • r741984 Jun 26, 2009
    I Have Windows Vista Home Premium.
    I have bridged connections, shared connections before...
    When it comes to setting IP's and what not, to use the same gateway ip and set Static Ip's.. i get confused.
    P.S. There is another SAME WRT54G router with the same IP in the Area. is this a problem?
    • I Should have to say right about now.. That When It comes to technicalities, i'm not sure.
      1.
      Like What should the TCP/IP be set to? Automatic or Manual IP?
    2.
    And should I connect my ethernet cable to the "Internet Port" on the router? or into 1 of the 4 outgoing ports?
    I've tried a million settings it seems. :(
    I've tried everything... Like i really feel like i did.
    SiY11 solved this issue. Thanks.
    I just need to know how to speed that connection up now =)
  • Jeffrey Carter May 11, 2010
    What version of Windows do you have?
  • 24 Answers
Http://windowshelp.microsoft.com/Windows/en-US/help/bfd3bd31-82f0-4b9c-9cde-fb92bc2b14771033.mspx
Enabling ICS
To enable ICS, on your host computer:
1. Open Network Connections by clicking the Start button , clicking Control Panel, clicking Network and Internet, clicking Network and Sharing Center, and then clicking Manage network connections.
2. Right-click the connection that you want to share, and then click Properties. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
NoteThe Sharing tab will not be available if you have only one network connection.
4. If desired, you can also select the Allow other network users to control or disable the shared Internet connection check box.
5. Optionally, to allow other network users to use services running on your network, click Settings and select the services you want to allow.
When you enable ICS, your local area network (LAN) connection gets a new static IP address and configuration, so you'll need to reestablish any TCP/IP connections between your host computer and the other network computers.
To test your network and Internet connection, see if you can share files between computers and make sure each computer can reach a website.
Once you have done the above, connect the Ethernet cord to the WAN/Modem port on the Linksys router and set the router to Dynamic IP. Then connect another computer to one of the LAN numbered ports on the router and they will have internet. Remember your computer MUST be on for the computers connected to the Linksys to get internet.
Posted on Jun 26, 2009
  • Jeffrey Carter Jun 26, 2009
    “P.S. There is another SAME WRT54G router with the same IP in the Area. is this a problem?”
    SiY11- You can change the SSID in the router so it does not display WRT54G if you like, this way you know which one is yours. They can have the same IP scheme it is fine because they are separate networks.
      1.
    SiY11 – set to Automatic…
    2.
    And should I connect my Ethernet cable to the "Internet Port" on the router? or into 1 of the 4 outgoing ports?
    SiY11 – Connect the Ethernet cord from your computer into the ‘Internet’ port on the router.
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
How to retrieve password from wireless access point router zyxel -570u
Initial Set-Up
Plug your wireless router into the cable connection in your wall. Plug the connection cord into the "WAN" port on the router. Plug the router's power source into the wall and turn the router on. Connect your wireless access point to your router by pushing one end of an Ethernet cord into the WAP. Push the other end of the Ethernet cord into the "LAN" port on the router. The WAP connects your wireless devices to your router.
Connect your laptop or computer to the WAP. Click the "Start" button on your computer and then click "Control Panel." Click "Network and Internet" and then select "Network and Sharing Center." The "Network and Sharing Center" window opens.
Click "Set up a wireless router or access point." Click the "Next" button.
Follow the prompts to create a wireless pass phrase or security key. Write the key down in a safe location to ensure access later, if required.
Aug 30, 2011 | Zyxel ZyAIR G-570U - Wireless access point...
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
How do i connect my laptop to sony bravia using UWA-BR100 ?
Connect the Laptop and TV with a *CROSSOVER* ethernet cable and then enable "Internet Connection Sharing" on the Laptop's "Wireless Network Connection".
To enable "Internet Connection Sharing", open the Network Connections folder ("Start > Run" type NCPA.CPL and click OK). Right click the Wireless Network Connection, select Properties and then the Advanced tab [XP] or Sharing tab [Vista]. Tick the box "Allow other network users to connect through through this computer's internet connection.
Mar 02, 2011 | Sony UWABR100 Network adapter USB ...
How do I connect to laptop when using a sierra Wireless Key?
On your laptop, enable "Windows Internet Connection Sharing", and run a "crossover" (not "straight-through") Ethernet cable from your network-port to the WAN port on the router.
Then, your laptop becomes an "Internet gateway" for the router.
Jul 30, 2010 | D-Link Xtreme N DIR-655 Wireless Router
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Connect two computers together
Technically, yes. Both computers should have an Ethernet port (LAN), a crossover networking cable, peer to peer networking using static IP add, and Internet Connection Sharing on the PC with the Wireless Internet Connection. If by chance the PC with the Internet access is already using its Ethernet port, a second NIC could be installed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Computers & Internet
Xbox live on this laptop
I assume you have a crossover ethernet cable.
put the my network places on your desktop.
right click on desktop/properties/desktop/customize desktop/tic
then on the network places icon on desktop right click/properties
right click on wireless and bridge devices
they are now sharing the same ip
be sure and remove /delete bridge when not sharing as the ip will stick forever likely.
that should do it if you need more info /open my computer and hit help and search for internet connection sharing as the firewall may need to be configured.
Jan 30, 2008 | Sony VAIO PCG-K35 Notebook
Ps3 wireless
It depends... If you use a router for the Internet then you don't need any cable, just turn on the router and then go to the PS3 and configure the PS3 to work with the router. If you have wired internet, then you will need an Ethernet cable, but since the PS3 comes with an Ethernet cable, you don't need to buy one. With the Ethernet cable, you have 2 options. If your modem has an Ethernet port, then just connect the PS3 to the modem directly. If the modem doesn't have an Ethernet port or direct connection won't work, then you can use Internet Connection Sharing to connect your PS3 to the Internet.
Jun 29, 2007 | Sony Playstation 3 (PS3) Console
Acer Windows Vista TL-562G Notebook Logo
191 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
