Question about Hamilton Beach BrewStation 47224 Coffee Maker
I can't program my coffee pot. the program button is not working. the green button when pushed does nothing, I can't program the time and it will not light up
  • Katherine Guy Jul 06, 2018
    SO what is the issue with this???? Mine is sporadic in the use of the program... once a few hours of being unplugged helped restart the green program button at lease for a hand full of times now doesn't work again also partially took it apart also made the program restart too. Now not working AGAIN .... HELP PLEASE with this issue???? a fix would be nice besides calling HB Cust Support I am willing to take it apart if I have to to fix???
  • 14 Answers
CALL HAMILTON BEACH AT 1-800-851-8900. THEY WERE WONDERFUL IN GETTING MY PROBLEM SOLVED AND ARE SUPER IN CUSTOMER SUPPORT.. 1-800-851-8900
Posted on Jul 13, 2009
I cannot get the clean lite to quit blinking on my Cuisinart coffee pot, HELP!!! I have changed the filter and run vinegar through it. Nothing works
See the manual my coffee machine has a program i need to hit 2 buttons it will flush 1 time i need to hit them again it flushes again then i need to do it 1 time again, then the light turns off, and never use vinegar, but lemonacid..
Jan 21, 2018 | Cuisinart Coffee Makers & Espresso...
We poured the amount of water needed to make the amount of coffee desired but 30 minutes later no coffee was made. Does the bottom "warmer" button need to be on or does the maker just need to be...
The tank inside holds about 2 and a hlalf pots of water. Once the tank is full, whatever you pour in will come out. The unit has to be plugged in to make coffee. Leave a pot under the brew funnel and pour a pot of water in. If nothing comes out within a minute, pour another pot of water in. Still if nothing comes out do it again. This time for sure water will come out. It will take avout 10 minutes to get hot enough the first time it is full to make coffee. If you have a thermometer, the water should be about 190 degrees F to make coffee correctly.
Oct 28, 2010 | Bunn VPR Coffee Maker
Coffee only pours a half a pot at a time when I
Check / set the timer for a longer brew cycle.
Mar 10, 2010 | Bloomfield 8572 Coffee Maker
Coffee maker stoped working
  • Make sure the power supply is all rite (if not try with different socket)
  • If your able to seee light..then try re-programme it using buttons.
  • Still if you face same issue ..i request you to call technician.dont try any thing,Give it to safe hands
  • Thanks
  • Jul 22, 2009 | Gevalia 50041 / 50443 Coffee Maker
    I need an instruction booklet to set the timer for the coffee.
    Go to Hamilton Beach dot com, pull down customer suppot menu, click on use and care guides, type in product and model number, click send and your manual will load. Print it out so you have it. Setting the timer is a piece of cake, Hold down the program button until the clock flashes. While still holding the program button down, set the timer for whatever time you want the pot to perk. Let go of the program button. To check if the timer is set right right, puch the prigram button just long enough to see what time it is set for. If it's right, prepare the pot the night before, push the program button to set and forget about it. It will perk at the time you set every morning. Katherine
    Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
    Do not know how to program fresh start oasis full button over fil
    Remove the brew basket and water defuser (sprinkler head) it should come off with a 1\2 turn.
    Place your measuring pitcher or empty pot in place.
    Turn the main power switch off in back of unit.
    Press and hold the Brew(full pot) button.
    While holding the Brew(full pot) button turn the main power button in back to on.
    Once the red light flashes over the Brew(full pot) button release it, then press it once to start the brew cycle.
    Let it flow until desired level in pot or measuring pitcher.
    Press the Brew(full pot) button once to Stop.
    Press the Brew(full pot) button once again to lock the settings into memory. Memory will store the settings even if machine is unplugged.
    Half pot button is automatically set.
    Apr 09, 2009 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
    Farberware FCP512S coffee pot instructions
    How to set the time:
    Plug the unit in
    Wait until the hour on the LCD starts blinking
    Press the CLOCK button to set the correct hour
    Press the SET button to switch to minutes
    Press the CLOCK button to set minutes
    Press the SET button to accept the time
    ***there is no AM icon, only PM***
    How to program delay brewing:
    Press and hold SET until the hour begins to blink
    Press PROGRAM until you see the tiny bell icon on the bottom of the screen
    Press CLOCK until you get to the hour you want to start brewing
    Press SET to switch to minutes
    Press CLOCK to get to the minutes you want to start brewing
    Press SET to finalize
    Press PROGRAM to activate. When the little bell is flashing, the coffee pot is set to go on at the desired time. While the coffee pot is on or in warming mode, there are vertical lines on the top of the LCD screen that shows you it is on. If you press the ON/OFF button, you can turn it off before the two hour keep warm cycle is complete.
    Hope this helps
    Sep 09, 2008 | Mr. Coffee ISX23
    Re: KitchenAid Coffee Pot
    I had a similar problem with Err 1, Err2, and Err 4. To resolve Err 1, if you have room, remove the coffee filter and coffee, pour more "warm" not hot water into reservoir. If you have 4 cups cold water add 5 cups warm. Then start coffee maker and let it run thru. Then drain coffee pot and start over to make coffee with tepid water. Err 1 indicates the coffee maker temp sensor is too cold from room temp or water temp.
    Err 2 is a result of cleaning. First question "Did you remove the charcoal filter?" The charcoal filter can be removed form the filter stick by prying two tabs away gently and removing the filter for removal. The filters can be purchased @ www.Kitchenaid.com
    One pot run thru with descaler can loosen scale and make sensor go "blind". Just run a full pot of clean plain water thru one maybe two times. A pot solution should be a solution of 1/4 pot WHITE vinegar, 3/4 pot clean cool water. Run this thru once, then two clean pots of fresh water as if you brewed a pot of coffee. NEVER USE CLR WITHOUT RUNNING NO LESS THAN THREE CLEAN WATER POTS THRU MAKER!!!! This is so you can continue to enjoy drinking coffee, nothing like a cup cleaning you out!
    Err 4 is simple, you have a stuck button. Unplug maker and gently press each button making sure they aren't stuck in.
    Jul 20, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
    Keeps flashing 12:00
    I just kept plugging and unplugging the coffee pot. Eventually, the clock stopped blinking, the buttons worked, and all was well.
    Jul 19, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
    Nothing works, only flashing program light and time
    listen to this! we called Cuisinart at 1-800-726-0190 and they are going to sihp us a replacement coffee maker and all they are going to charge us it the price of shipping. good news since spending so much for a product. great customer service.
    May 28, 2007 | Cuisinart Thermal DGB-600 Grinder
    Hamilton Beach BrewStation 47224 Coffee Maker Logo
    413 people viewed this question
    Top Hamilton Beach Coffee Makers & Espresso Machines Experts
    jason
    80stech
    Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
