I Have this older model Mitsubishi VCR HS-G21, like most VCR's, but i have a camera, that works fine when connected to the tv, but can't seem to get the input mode on the vcr to work. I need to record from my security camera to my VCR.
I've gone through every channel, every mode, On the back on the VCR it says, "To change Ant from Ch. 3 to Ch. 4 then do 'This' " and i did it on both channels, still nothing. Got a universal remote... Still nothing.
Can you help me figure out how to do this?
Thank you. ~ Ryan [email protected]
SOURCE: New VCR Old TV
Hi This problem has been around for some time when connecting a DVD player to an older tv, and now has become a problem with newer VCR's. You must purchase a device called an RF Modulator which will allow you to connect to the older tv. We sell them at our shop for $30.00 but I have seen them quite often for $65.00 and up...so it pays to shop around. Good Luck
SOURCE: Mitsubishi HS-U447 VCR in Lock or "Loc" mode
There is a reset for this problem and it worked for my VCR. This was a last resort without the manuel.
Only someone with electronics experience should do this.
SOURCE: universal remote code for Emerson EV598 VCR
The codes only go back so far in regards to the capacity of the memory of the remote. Sorry...accordianman
SOURCE: Mitsubishi HS-U61 SVHS
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor. Unplug the unit and take the cover off. Hopefully there will be enough clearance so you can get to the tape. Try to find the motor and belt that is responsible for operating the eject mechanism. The motor will look like a shiny cylinder, about the diameter of a quarter and will have a plastic pulley attched to the shaft. You can rotate the pulley and belt with your fingers and manually eject the tape. If the tape is around the spindles and video head, you will need to manually move the mechansim that retracts the spindles and returns the tape to the cartridge. While you may be successful in getting the tape out, you need to find out what caused the problem in the first place. Putting in another tape will most like become stuck again unless the problem is identified and resolved. Also look for a broken spring or cracked gear (missing teeth) in the eject mechanism. Please let me know if I can be of further assistance Good luck! - Jim
SOURCE: VCR will not switch to program mode
Solved my problem by reading a previous post about taking apart the remote and cleaning the contacts. Believe it or not it the remote is working again.
