My outside air conditioner fan is not turning, but when I push the reset button it runs for a while and begins cooling? Then it stops turning and gets hot inside again? What could be the deal?? It was 112 today PLEASE HELP
if the button your pushing is in the unit outside it is a manual reset for high head pressure this cuts off the unit to protect the compressor,you need to clean the coil .turn the unit off and gently push water through the coil in an up and down motion till water comes out clean see if that helps
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights...
(More)
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights flashing. The outside unit takes long to come on.
when this happens i open up the unit outside & there is only one test light flassing. i have to...
(More)
WHEN THIS HAPPENS I OPEN UP THE UNIT OUTSIDE & THERE IS ONLY ONE TEST LIGHT FLASSING. I HAVE TO SHORT OUT THE TEST PINS & THEN IT WILL WORK FOR JUST A LITTLE WHILE THEN I HAVE TO REPEAT THE ABOVE STEPS.
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is...
(More)
I HAVE A OLD RUUD PACKAGE UNIT THAT NEEDS TO BE CHANGED OUT DO YOU HAVE A REPLACEMENT UNIT THAT IS COMPAREABLE TO THE OLD ONE TO MAKE IT A QUICK SWAP? MODEL#URGG-10E60JKR
