Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
My switch broke and i had to replace it with a universal switch but it wont work because the letters dont seem to match
  • Dwain Pippen May 11, 2010
    Have you considered buying the correct switch?
  • 389 Answers
You cannot use a "universal" switch unless you rewire the tractor to the switch and most of the time you can't even do that because they are a magneto ignition and the universals are made for battery ignitions. Obtain the proper switch and install it and hopefully you haven't burned up anything by using the wrong switch
Posted on Sep 29, 2009
My turn signals wont turn off even after i make my turns. it was working just fine till i went and had my oil changed. what do i do?
The two are not related. Seems plastic tab broke inside switch within steering column. Replace switch.
Jan 02, 2016 | Cars & Trucks
The plastic over the on/off button broke, shredder does not turn on. Can this be replaced to work
It appears that the controls are covered by a film with symbols printed on it; this shouldn't have disabled the machine and this type of control has no dangerous voltages present so safety is not an issue.
This type of control generally uses small carbon buttons or a tiny enclosed switch assembly and neither of these are very durable and may not be making contact as they should.
Another possibility is that an internal switch that is activated by the paper inserted may have failed.
There does not seem to be a manufacturer named 'Universal' but the link below is a Chinese maker with a model very close to yours:
View Product Details Shredder paper confetti cut paper shredder
You seem to have no recourse other than contacting the firm that sold you the machine for service.
Good luck=
Feb 03, 2015 | Universal StripCut Shredder UNV48025
I wired my timer switch wrong i need to know which colors go where
The fuse is located on the heater housing we4x800 is the part number on most of these. Look closely at the wires on the timer each one has a letter on it the letters on the wire matches the terminal markings.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2012 | GE DBXR463EDWW Electric Dryer
Turn signals wont work a puff of smoke came out the hazzard button then i lost my turn signals
the hazzard switch needs replaced. the hazard switch also control the turn signals? cuz i broke mine today and the turn signals dont work ... good-day!
Aug 22, 2011 | 2001 Chevrolet Blazer
My touch screen keeps messing up, certain letters dont work.
I recommend you backup your favorites.
Then attempt a hard reset.
Finally, replace the firmware and system software using webupdate.
Replacing the system software will most likely correct the malfunctioning keying of letters.
I hope that helps.
Apr 03, 2010 | Garmin nuvi 205 GPS Receiver
The origional power cord broke and we have tried to use several universal power cords....But they don't last long. It seems like the connector doesn't exactly fit.....Dont want to replace the whole...
I have same brand and model and my motor broke so that disks no longer spin, so I have an extra remote, car adaptor, battery and power cord. If interested contact me here or they will be listed in my ecrater store here
Oct 15, 2009 | TruTech PVS12701 Portable DVD Player
My truck almost burned up today when an electrical fire broke out under the dash. Imediately disconnected the battery had it towed home. Then proceeded to find out what happened. I found out wires coming...
switch you can get at the dealer or aftermarket normally if u want to keep your same key its better to get it from the dealer and rebuild the new tumbler to match your key if u dont care u can get it aftermarket with a different key as far as the connector i work at a dealership so i can look it up but i will need the vin email it to me and il let you know thomaspedemon1@yahoo.com
Jun 30, 2009 | 1988 Ford F 150
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
there is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Jan 14, 2009 | Nakajima AE-710 Typewriter
2 cameras one charger
Greetings Juana1,
Model G and Model E batteries are of different size and connections, therefore the dedicated chargers wont work for both. You may be able to find a universal charger that can accomodate both, however Sony is fairly proprietary with items to match their products.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 08, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
81 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
