Can any one tell me where the oil drain plug is on a 2012 dyna wide glide
SOURCE: oil drain plug 2004 harley dyna wide glide
your oil drain is on the right side pipe side of your bike look under near the rear back part of your frame you will see a plug with a one quarter allen key threaded plug style bolt kinda hidden in bridge plate of frame it is flat in conjuction with line on bike it is in area right behind where your back pipe expands to baffle of pipe where its skinny and then gets bigger its the one closest to you
SOURCE: 03 HD dyna wide glide blows oil from breather...
How many miles do you have? You probably need to have your oil pump alligned. They get out of wack and cause over oiling. I believe it caused by not being able to return oil efficiently. An evo tappet block alignment tool is now used to align the TC internal oil pump.
SOURCE: capacity of primary oil on a 01 dyna wideglide
Three quarts. Check the oil level with the bike on the side stand. The dipstick has two marks on it. The top mark is "Full Hot" and the lower mark is "Full Cold". Maintain the oil level between the two lines. Do not overfill.
