Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Sound hi, basically when i playback anything its always has a watery echoe sound
  • 117 Answers
Reinstall your sound drivers
or this is speaker or mic problem
Posted on Nov 07, 2007
Echo through speakers
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
Sep 15, 2012 | ASUS Computers & Internet
My sound out of the speakers in my laptop, constantly echo's when ever i play any kind of sound. please help!
Try restarting your computer or looking at the settings to your sound by right clicking on your speaker icon and go into playback devices then go to your speakers and playback then adjust the settings then run a test of the sound system by going to the last tab and clicking test.
May 25, 2011 | Computers & Internet
I have a Swisstech 15"
Hi michael_b975,
Please check the audio settings and disable the echo mode , or anything similar to that , if there is an option for default settings , please choose that option so that you would have normal sound.
May 10, 2011 | Televison & Video
When i plug my speakers into headphone socket i gets an ehco on my advent netbook why is this?
Hi dichubby, to fix the "Echo."
Do the following:
paul7of9_81.jpg From the "Desktop Screen," [Right / Alt] click on the Volume Icon. paul7of9_82.jpg
Once the 'window' open!
Select the "Playback Device" shortcut.
paul7of9_167.jpg Next, highlight the Speaker icon,
or {2x click} to open the [Properties] 'window'.
Select the Enhancements" {Tab} ...
"You can place a [Check] in the "Disable all sound effects."
Or click on the Settings: Down-arrow, and choose a "Sound Effect, 'or' None!"
This should fix the 'echo.'
Click on the "Apply and OK" button when finished!
!"Take a 'moment to rate the help" Thanks
Mar 19, 2011 | Advent Netbook
How do get rid of echo on sound from speakers?
When you say echo, are you meaning sound coming from your mic echoing thru the speakers or a sound like your in a bathroom on all audio.
If you are referring to the mic issue, then open your volume control and make sure that MIC is muted in playback setttings
If you are refering to bathroom sound on everything , it is called a "environmental setting" and in in your sound cards software setup, like their version of the volume control or some other application they have installed for you to configure your card. Just locate the "environmental" setting and disable it / set it to none.
Sep 25, 2009 | Computers & Internet
Sound Problem
one of 2 things is going on either you have to cheap a headset/mic or your need to mess with the mic boost and other mic settings to get it just right.
Apr 01, 2009 | Computers & Internet
Cusinart ICE-25 will not freeze ice cream, the product is watery.
just basics, looks to me that the refrigerant i.e. 134a or similar is depleting over time and not cooling anymore. u need to have it serviced. that's all if everything else works fine.
rudy.ky
Jan 09, 2018 | Kitchen Appliances - Others
I messed with my sound
echo due to playback setting on mic controls. ??
Go to sound properties and enable all slider controls both for Playback and Recording. Look at Recording sliders and mute any that you don't need (esp. Mic Playback).
Aug 03, 2008 | Acer Aspire 5610-4648 Notebook
Echo indigo io recording problem
dont plug mic into output, it is input
May 24, 2008 | Echo Indigo IO Sound Card
My pc sound system has a bad echo..
try uninstalling sound drivers and reinstalling them (or newer)
Nov 13, 2007 | Compaq Presario 5000 PC Desktop
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
200 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
