Question about RCA WSP155 Main / Stereo Speaker
RCA WSP155 wont play in all modes
My RCA WSP155 wireless speakers are being used with a Philips MCD515 micro home theatre. The wireless speakers work great when in DVD mode but when in aux (television) or radio mode they do not receive a signal. If I plug the wireless into the headphone jack on the front they work in aux or radio mode but the stereos main speakers shut off.
Any suggestions how to get the wireless to play in all modes? Thank you.
  • 3 more comments
  • yesterway Jun 26, 2009
    Please respond to original comments
    I have the wireless transmitter plugged into the red and white rca audio out plugs on the back of the stereo using a y connector. For some reason when I select radio or aux mode the signal from the stereo is not being recognized by the wireless transmitter. There are no audio settings on the stereo to adjust. The tramsmitter must be connected correctly to the stereo because the wireless speakers work grat in DVD mode.
    Please refer to the previous comments.
    There are no batteries. Please refer to the original comments.
    The speakers are plugged into the wall. They are not on battery power. As I said in the original post the wireless speakers work great when in the DVD mode so that tells me all is well. The problem seems to be why the speakers do not work when the stereo in in radio or aux mode.
  • 250 Answers
Do you receive radio signals at your home?
is the antenna pulled if there is an antenna?
does your system support radio signals?
Posted on Jun 26, 2009
    President:
  • 1,734 Answers
There are batteries! (8 x “D” size Alkaline batteries) - 4 per speaker
So you need to ensure the following:
A) Check that power adapters and/or batteries are
connected properly and that power is on.
B) Make sure the control knob on the speaker is ON.
C) If using batteries, they may be too weak to
power the speakers. Replace the batteries.
D) Ensure the TV or audio component is on
and that the unit is receiving an adequate
audio signal.
E) The volume control knob on the speaker is set
too low. Adjust the volume if required.
  • 240 Answers
Try changing the batteries..
  • 483 Answers
  • 378 Answers
Check the audio setting of the micro home theater. check set it 2 stereo or movie
  • 555 Answers
My friend if you are using aux in tv or radio kindly  check the connections into the receiver, and ensure that the cable system or antenna is connected directly into your receiver, and that you are using the tuner with the receiver, not the one on the TV.  Also if you plug the wireless into the headphone jack try also to check the setting of your stereo to ensure that your main speakers neve shut off else it has something going on your setting configuration. Also you can try reconfigure and reset your settings in wireless to allign in your device using to ensure that all modes will play. Cause if you want to your wireless plays in all modes then the only you can do to make it work is by checking the connection of the receivers or you can edit and set your setting to adjust and work your wireless to a device you plug  or connected with.
Hope this suggestion helps your problem. If you need more assistance just reply to this post or contact me so that i can find new solution if this suggestion doesn't work.
If this solution works kindly rate this solution please. Thank you and godbless Thanks.
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
Philips troubleshoot
It an issue with most Home Theatre.The surround speakers do not work automatically unless the system is set on surround mode.The audio mode or surround button can be used to select the surround mode.
Dec 22, 2013 | Audio Players & Recorders
Why do only 2 speakers play in steroe mode
stereo mode is just that - stereo. Stereo is two speakers, front left and right only. If you want the other speakers to play, select a surround mode.
Jan 29, 2013 | RCA RT2380 Home Theatre System System
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
RCA Wireless speaker
This happened to one of ours, it turned out that the plug was damaged. Try using batteries and see if it will work, if so, you know that you need to just get a new adapter plug. Good luck!
Jul 25, 2008 | RCA WSP155 Main / Stereo Speaker
Rca wsp155
There should be a mini connector (Male) connection to 2 RCA (MALE) Connectors. You just hook the output of computer (Mini) plug to that then hookup your RCA connectors usually white and Red to the transmitter and it should work fine. Try the premium area if you need further assistance. Guru Jay
Jan 28, 2008 | RCA WSP155 Main / Stereo Speaker
Can i play my mp3 HDD through the Unit speakers
if it has red/white RCA style inputs on the back you can just buy a cord that will plug into the headphone of your MP3 and into the RCA jacks on the stereo.
Sep 07, 2007 | Philips DVD Micro Theater Shelf System...
Problem adding wsp155 wireless speakers.
You must check with the instalation gude for the wireless speaker to see if the connection to the reciver is a high impedence or low impedence... If its like most wireless set-ups its going to be a high impedence output from the reciver to the transmitter part of the speakers. That would be from the RCA jacks in the back of the reciver maked line out or tape out. If you want to use them for a specific speaker output , some recivers have an output jack that would be labeled center sperker out but would be an RCA type jack ect ect. If your reciver dosent have that you can in a higher end audio store get an adaptor to convert the speaker output to a high impedence, But I dont recomend that as some of the adaptors do cause excessive strain on the output section of the amp or reciver.. If you buy a good one though you should be fine.. You get what you pay for.. Good Luck
Aug 06, 2006 | RCA WSP150 Main / Stereo Speaker
RCA WSP155 Main / Stereo Speaker Logo
155 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
