Question about Garmin nuvi 765T GPS Receiver
Garmin nuvi keeps dropping the sattelite - Garmin nuvi 765T GPS Receiver
    Problem Solver:
  • 10 Answers
My garmin nuvi 250w is charging but no maps come on screen or cant aquire sattelites
contact me directly, I will try to help, my e-mail: service@gps.pol.pl
Sep 23, 2011 | Garmin nuvi 250W GPS Receiver
My garmin 350nuvi will not acquire sattelites
Make sure to flip your antenna horizontally or 90 degrees and not vertically or 180 dgrees. I see to many people try to use their older nuvi this way and it does not function well.
Try also updating your unit with the latest firmware from Garmin, this helps sometimes.
You may have moved to a location that is far away from the last location your Garmin nuvi 350 was last use, try to keep your unit on for 30 minutes or more to see if it will acquire GPS sattelites.
Last, certain vehicles have shielded windshields and GPS does not work well with these windshield, this can be eaisly verify by simply taking your nuvi 350 out of your vehicle and turn it on with a clear view to the sky, if that still does not work, it could be a defective GPS receiver or GPS connection in which case you should consider sending it in to Auto Nav 2000 Plus, Inc in San Jose CA or Garmin.
You may also consider replacing your nuvi 350 with a newer model nuvi with fresher map.
Good luck
Apr 03, 2010 | Garmin Nuvi 350 Car GPS Receiver
Garin nuvi 200 cannot aqcuire sattelite
Acquisition of satellite speed has been addressed in new firmware / system software updates for the Garmin Nuvi 200W .
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 08, 2009 | Garmin nuvi 350 GPS Receiver
Nuvi 350 finds satellites but won't lock on
Please read this solution, which might help you. On the Nuvi 350, press and hold the lower left corner while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 660 Can not locate Sattelites
Please read the solution that resolved this problem for someone else. Most likely, you have already tried this. However, the antenna of your Nuvi 660 is the same as the 3xx Nuvi series. I know this because I have worked on them.
http://www.fixya.com/support/t1115882-garmin_nuvi_360
If the above procedure does not work for you, the entire antenna assembly will need to be replaced.
The other option is to purchase an external antenna for your Nuvi and plug it into the external antenna port (gold connector) on the Nuvi antenna assembly.
Best wishes,
- Jim
Oct 21, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 350 GPS will not find sattelite
I GARMIN KEEPS SAY MEMORY IS FULL HOW DO DELETE IT
Feb 12, 2008 | Garmin nuvi 350 GPS Receiver
GARMIN C330 WILL NOT LOCATE SATTELITE
Have you tried a Master Reset? It may help, but it WILL ERASE ALL OF YOUR FAVORITES. To do a Master Reset, turn the unit off. Press and hold the bottom right of the screen, then press and release the power button. Keep pressing the screen until the unit asks if you are sure you want to reset. Follow the prompts.
Feb 09, 2008 | Garmin Nuvi 370
Garmin nuvi 765T GPS Receiver Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
