Question about Troy-Bilt Chipper Shredder
Pull-start rope won't pull
I'd been using the chipper/shredder, shredding mostly oak leavesand pine needles, for about an hour, when I had to shut it off because it was not spitting anything out. I didn't see a rock or any other problem, so I went to start it again and the pull-start rope won't pull at all. It is encased so I can't see the rope, but it doesn't feel like it is tangled. It just won't pull at all. Any ideas? If there is a rock somewhere inside, jamming blades, would that prevent it from pulling, since you can't stop the blades from turning while it's running? I had started it about 3 times in that hour already.
This has happened several times for me and is usually caused by a peice of word jamed in the input hopper and half cut by the blades. Always make sure there is no wood in the input chute before stopping motor. remove the collector bag and use a long pry bar to reverse the flywheel. if this moves backwards you may then be able to remove the peice of wood jammed in the blades thru the input chute. Long Skinny arms is required to reach down the chute. Use a Flashlight to see if this is your problem.
Posted on Jul 12, 2009
  • 398 Answers
Can you turn the blades with a peice of wood? Offhand though could be a seized motor, oil check OK?
-Carl, please let me know if this helps.
Posted on Jun 26, 2009
Can you mulch palm fronds on a kemp chipper shredder or what do you not run thru the shredder
most anything fresh green is difficult to shred
allow a day or three for the sap to dry out and they they shred fairly easily
Apr 04, 2018 | Heavy Machinery
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
Beeps and stops; doesn't stop when empty
As for your first part - It sounds like there is something wrong with the switch lever that moves to complete the electrical circuit to start the shredder. On every shredder I have seen, there is a little "bellows" linked up to this lever that pushes it back so the machine will shut off. Most of the time all you have to do is put another piece of paper in and let that get shredded and the shredder will stop afterwards. If not, then just use the main switch to turn the shredder off.
Second, the beeping during "mid-shred" sounds like a warning that the shredder is starting to overheat and shut down. If this is the case, just wait a few minutes to allow it to cool down and try to finish the shredding you have. I have found that if you feed a shredder a constant stream of paper to shred, this might cause the shredder to overheat.
Also, the shredder may get overloaded with pieces of the shredded paper. Here is the way to check on that:
1. UNPLUG THE ELECTRICAL CORD FROM WHEREVER YOU HAVE IT PLUGGED IN.
2. Lift the shredder from the bin and turn it upside down.
3. Look for an excessive amount of paper in the bottom of the shredder. If there is a lot, you can remove it in several ways. (Most likely the bin is quite full at this point.) Pull the majority of it out and put it in the bin. If there are pieces of paper that you can pull out with your fingers, use a tool (needle-nose pliers, serrated tweezers, a hemostat, etc.) to get those difficult pieces out.
Replace the unit on the bin making sure that it is the same way you took it off. In most cases (on the better shredders), there is a notch on the underside of the shredder that needs to be on top of a "nub" that is on the edge of the inside top of the bin. Unless that nub is aligned with the slot, the shredder will not work.
Apr 26, 2014 | Staples ID Armor IDX50B Shredder
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Have a new electric shredder does not have
Brand new shredder with no owners manuall I plugged it in.it won't start is there a first time procedure t o use it
Jul 10, 2010 | McCulloch Electric Chipper Shredder
I PICK UP A 3250 TROY-BILT GEN AND RAN IT 1 FULL TANK OF GAS OK. THAN WE GOT A SECOND STORM FILLED TANK AGAIN LET RUN FOR ABOUT 6 HOURS AND IT STOPRD. WHAN I THAUT IT RAN OUT OF GAS I REFILLED AND TRYED TO...
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
Replace flails on 5.5 Yard Machine
Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
Replace them you have to take casing off the unit to get to them.
Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Just bought a 10 hp troy bilt chipper used. When
If fuel is leaking from the fuel filter, replace it. If fuel is flowing freely into carburetor and overflowing, it is likely the float, needle and seat.
May 18, 2009 | Troy-Bilt Chipper Shredder
What is a chipper?
Most of our industry refers to chippers or chipper-shredders as pieces of equipment that can handle both wood and leaves. These machines have both a chipping device and a leaf-shredding mechanism. This mechanism is basically a hammer mill, cylinder or drum with a series of pivoting flail-type knives. The chipper-shredder usually is a smaller machine and may include a vacuum to clean up leaves. These machines can be self-propelled or stationary. Most chippers are disc-type, consisting of a large, heavy, rotating disc with knives mounted to it and are for chipping wood only.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Turns on when paper in slot, but won't pull it through to shred.
must disassemble feeder unit. you will find many bits of shredded paper to pull (push) out with a long narrow tool like a crochet needle.
Jun 19, 2007 | Royal AG10X Shredder
Troy-Bilt Chipper Shredder Logo
1,404 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
quennie732
Mike
lnbn1975
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
