Question about Huffy Disney Princess 16 in. Girls Bicycle
How to raise the handle bar in huffy 14" princess bicycle??
    Problem Solver:
  • 7 Answers
The silver bolt on the neck behind the handlebars. Losen it off a few turns, and the entire stem can be raised and lowered. Be sure not to raise it too much, should be a minimum mark, or else leave a good inch or two still in the frame, and tighten it back up. Make sure it's aligned with the front wheel though!
Posted on Jul 01, 2009
Can not raise the handle bars on the Huffy Mojava Gulch?
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
May 11, 2011 | Huffy 26 In Ladies Mojave Gulch Bike
Brake system. how to install the brake system for huffy disney princess 16
The link below will take you through the brake assembly and how to use the brakes on a huffy princess bike. Go to page 30 and page 31. A diagram shows how the brake arm should be secured.
http://www.huffy.com/pdf/ownersmanuals/e0664c94-726b-49d6-8322-5e053dca5b0a.pdf
For more information on bicycles, bike safety or bicycle accessories, visit my website: Huffy Bikes
Dec 25, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I bought the huffy 16"
It's pretty hard to know how to help you exactly. But this may help--- if you have (or can borrow) a digital camera, take close-up pictures of your parts then take the camera with you to a Wal-mart or wherever this bike is sold. Compare your pictures to one on display. Or better yet, take the whole bike with you. Or just take close-up pictures of the bike on display. It might also be useful to know that the front fork (that is the two metal bars about 10 inches long that point toward the ground that the wheel attaches to) sometimes have to be spread apart just a bit to fit the wheel's axle in place. I'm talking about maybe 1/4 inch or so. If it's a lot more than that the fork may have gotten bent in shipment and you should take it back.
good luck, Merry Christmas. Al K
Dec 23, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
I have a question about putting together a disney princess 12in bike, I put the handle bars in, but they don't seem to attch to anything. And the owners manuel is for multiple different bikes, so it is not...
If I understand your question, you put the handlebars into the front steering assembly but they don't attach.
On top of the handle bar is a screw that when it is turned in pulls a wedge shaped bottom piece up. When this is done once the handlebars are in the steering unit, the handlebars lock up and can't rotate or pull out.
If that doesn't answer your question, let us know.
Gary
Dec 21, 2010 | Huffy 12 in. Girls Disney Princess Single...
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
How do I get the seat and the handlebars on???
click on this to get your free set up. book.http://www.huffybikes.com/Support/OwnersManuals.aspx
hope this helps you. sawdust.
Aug 10, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
The handle bars is twisting around away from the front wheel
tighten up the castle nut that holds the wheel yoke to the frame.
Jun 19, 2009 | Huffy 16 in. Girls Disney Princess Single...
Huffy Disney Princess 16 in. Girls Bicycle Logo
440 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
