My screen looks like it is out of focus. The bottom and top of the screen is doubled.
  • jontibbitts Jun 26, 2009
    Thanks a million.
  • 13,433 Answers
Does it look like this?
That would be a convergence Ic issue and the IC chips would need to be replaced, Here is one guide on the subjecT:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jun 26, 2009
I cant scrol down because my lap top's screen is too far moved to the right. how do I drag the screen to the left?
There are more than a couple ways to get your screen focus back...
1. If you can click at the top of the screen and drag it to the left. Once you can see the edge of the screen you should be able to resize it within your parameters.
2. You can double-click on the top of the screen to make it full screen.
3. Right-click on the Task Bar and select Cascade Windws to see if you can get it back in focus.
4. Last resort, you may be able to change the screen resolution so that you get more resources on the screen.
Hope this helps!
Oct 05, 2014 | Computers & Internet
How to fix when out of focus?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-51DX80 51" Rear Projection...
The focus is off and we cannot get it back in
Convergence circuit needs repair call a tv repair guy looking at $300-$400
Apr 25, 2009 | Mitsubishi WS-55859 55" Rear Projection...
3 year old rca rear projection just started going blurry. green blue and red line across the top of screen. objects have shadow.
Focus and screen control box / remove front bottom panel there you will find it / it has 3 controls on top 3 on bottom top are focus for RGB tubes bottom controls adjust screen drives for RGB.
Jan 25, 2009 | RCA D52W23 52" HDTV CRT TV
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Samsung Hc-p4752e - Double Picture
Dane,
The convergence amps most likely failed. That unit takes two STK392-010 amps and the most likely cause for their failure are one or more of the 3.9 ohm 1/2watt resistors out in front of the Ic's which have opened or changed in value. There are several of them too, Rz142,143,146,147,144,145,123,124,125,126,127 and 128 and do check them all...
Bill
Nov 24, 2007 | Samsung HC-P4752W 47" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
