Question about Fujitsu fi-5750C Flatbed Scanner
Fi-5750C Fujitsu scanner can't change grayscale default setting
Hi. We have a fi-5750C Fujitsu scanner. It works great. But the "grayscale" option displays each & every time we go to Import the twain via Photoshop CS2 regardless of the settings we have saved & named. Most of our settings are for Black & White, not grayscale.
How can we get it to show Black & White by default instead of grayscale ?
Thanx
    Problem Solver:
  • 12 Answers
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Posted on Aug 20, 2009
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
How many lamps are in fujitsu 5750c scanner? how can i replace them?
Hi Albert,
There are two CCD lamps inside Fujitsu fi-5750c Duplex scanner.One is ADF Front and the other is ADF Back.To replace them, you may need the help of Fujitsu certified technician, for the procedure requires technical expertise.
Thanks & regards,
ScanCare
Nov 08, 2011 | Fujitsu fi-5750C Flatbed Scanner
Hi, I want to install both fujitsu fi 5750c and 5530C2 Scanners in same PC. OS is win XP. I tried through setup, but when one is installed, second one's setup says already having Scanner Utility...
There is no need of installing driver for fi-5530c2 scanner as the driver comes bendled in the fi-5750c scanner. Hence, please install the driver for fi-5750c.On the application, you need to chnage the scanner model under "Select Scanner" menu.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 27, 2011 | Fujitsu fi-5750C Flatbed Scanner
How to replace the front bulb in a fujitsu 5750c scanner
The front lamp assy replacement procedures involve technical expertise. Hence, you are recommended to get it done by a certified Fujitsu technician.
Thanks & regards,
ScanCare
Dec 29, 2010 | Fujitsu fi-5750C Flatbed Scanner
Is there a technical manual for Fujitsu FI-5750C Scanner that shows details of replacing parts e.g. lamps, glass etc?
http://www.fujitsu.com/downloads/IMAGE/manual/p3pc-e737-02en.pdf
http://library.princeton.edu/departments/tsd/order/invoicing/Scanner%20User%20Guide%20Fi-5750C.pdf
Hope this helps.
You may need a PDF reader software to see pdf type documents
like Adobe acrobat reader or foxit pdf reader.
Aug 18, 2010 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
Apr 30, 2010 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750C scanner error 4718 abnormal light dose
Azrael:
You seem very familiar with this unit I have a couple of questions:
1. Where can I get a parts and service manual?
2. How do I separate the scanner from the flatbed, so the unit can be packed for shipping in two pieces, rather than the humungous and fragile 80-lb. unit it is now?
Thanks in advance -- hope you get this message.
-- Roy Zider
Feb 24, 2010 | Fujitsu fi-5750C Flatbed Scanner
Is there a firmware update for this scanner, the
Thank you for contacting Fixya.
Firmware update for your Fujitsu Fi-5750C scanner is available. However, this may not be available to download.Hence, you need to contact Fujitsu Technical Support for the same.
Regards,
TechSatya
Jan 27, 2010 | Fujitsu fi-5750C Flatbed Scanner
How to disable Fujitsu fi-5750C ADF
Your scanner will never pass the initial boot "test" sequence without getting sensor and light readings. Cut the binding and scan it through the adf and save a few weeks work.
Oct 27, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fi 5750c adf will not initialise
Just something simple to try...check your software setting to see if it is set for ADF or Flatbed feeding. You said the light bar moves when power is interupted or the adf opened. But you never said if it is scanning in Flatbed mode. If the Flatbed scans, then check the software setting. Most of the flatbed/adf hybrid scanners start up defaulted to flatbed, so when you try to scan, the adf won't pull anything thru until you change to ADF mode.
Mar 13, 2008 | Fujitsu fi-5750C Flatbed Scanner
Fujitsu fi-5750C Flatbed Scanner Logo
617 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
