Question about LG 42PC3DC 42 in. Plasma HDTV
The tv not stay on.You can here a relay clicking on and off.But will not staw on.
  • 42 Answers
My guess is that the tv has no inverter(s) !! Its a plasma ! not a lcd.
I do not have an answer because the problem could be caused by many things...sorry...
My best guess would be :the power supply...
Posted on Jul 10, 2009
  • LG Master
  • 3,866 Answers
Check these things
!.power supply
2.inverter both master and slave
First start and the power supply then the inverter, if under warrenty take it back, if not and your still in doubt call the manufacture for the best repair option, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 26, 2009
SOLUTION 2 IS RIGHT THIS IS A PLASMA TRY UNPLUGGING THE Y AND X BOARDS FROM THE MAIN POWER SUPPLY IF CLICKING STOPS Y OR X IS SHORT IF Y REPLACE Y MAIN WITH SCANNING BOARDS
Posted on Apr 26, 2010
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Philips 42PFL5603D/10 relay clicking
Relay is on or connected to power supply--if clicks on and then off something (most likely on power board or something it feeds) is bad.
Some voltages from standby portion of power supply can be tested but since no paper schematics for this brand it will be hard.
Jun 11, 2012 | Televison & Video
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
I have a sony dcr v240. A black rubber roller
well this has been sitting for some time now. but the solution would be wd40! well the straw off of it really, put your roller on and then cut a peice the straw sometimes a can of air staw works to and carefully slide it on.
Jan 15, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba Color TV Relay clicks slowly. TV does not come ON.
Electrolitic Capasitors in the power supply going or being bad will cause this. At some point a low value resister also will start to run hot or burn up. I believe it it a 16v 1500 uf cap near the relay. I would also replace any 10uf 160v caps in the powersupply too.
Hope this Helps,
Skyassoc
Jun 17, 2009 | Televison & Video
Turns on but wont stay on
your start relay in the power supply has burned points and, loses it's connection shutting down your TV turn on the tv with the back off and, listen for the relay click to find it; then replace the relay
Jun 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Tv Power
It sounds like the backlight fluorescent bulb is burned out.
Oct 26, 2008 | LG 42PC3DC 42 in. Plasma HDTV
Hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Con
Jan 08, 2008 | Televison & Video
LG 42PC3DC 42 in. Plasma HDTV Logo
325 people viewed this question
