How do i fix delco anti theft radio security system that won't stop flashing lights
Tahoe had to be boosted and set off the anti theft system and caused the dashlights hazard lights and horn to flash and honk. How do I turn off dont have code.
i dont have a remote for the tahoe it will start, just the little red light, dash lights, and all other lights plus horn are going off.i dont have a remote for the tahoe it will start, just the little red light, dash lights, and all other lights plus horn are going off.
You can't post conmments that contain an email address.
is radio replacement an oem or aftermarket --when changing a radio which is part of anti theft system either need a unit that will flash or program to your vehicle
CarGurusFeb 3, 2014 - SECURITY SYSTEM LIGHT COMES ON - CAR TURNS OVER WON[T START ... Insert the ignition key into the driver door lock. ... When I start my car 3 keys programmed pops up on my dashboard what does that mean.
CarGurusFeb 23, 2011 - Why does the anti theft system keep tripping on my 03 malibu - Every other day my anti-theft system goes off in my car then I have to reset it. It's not ha... ...it needs a pass lock sensor/ ignition lock cylinder. 10 out of 10 people think ... Wait 10 minutes until the light stops flashing, then start. Repairs could run ...
Car Won't Start and Security Light is On on Oldsmobile 88 ... key turns over enginebut fails to start some times..security system keeps the fuel injectors from ...
Car Won't Start and Security Light is On on Buick LeSabre. Problems with the ... 1998 Buick LeSabreVisitor. Turn key on every thing come on but won't turn over.
Replaced trans, engine, PCM and bcm, now starter diabled- theft flashes on service ...1995 Bonneville car turns over but wont fire an security light is flashing car ...
It sounds like the anti-theft security system is engaged, this is keeping your vehicle from starting. I would recommend calling a local dealer where you are and ask them to help you. Hope this helps.
If the security or anti-theft light is flashing when you attempt to start your car, and the engine does not crank or does not start, you have an anti-theft problem. The system may not be recognizing your key's key-less entry signal, or there may be a fault in the anti-theft module or wiring. There is a reset procedure to stop this anti-theft light flashing.many a times this helps
The reset procedure is as follows:--
Reset the alarm by locking and unlocking the drivers side door.Do this a couple of times and then check it will reset the factory security system .If the reset procedure does not helps then its time to get the anti-theft system checked.There is a short circuit in the anti-theft system wiring.For more detailed help on this anti-theft light blinking issues please click on the link belowhttp://www.aa1car.com/library/troubleshoot_antitheft_system.htm Thanks. you can rate this solution and show your appreciation.
Make sure your battery is fully charged and good. Then leave the key on 'till the security light stops flashing (sometimes more than ten min). If it refuses to start or will not stop flashing, your ignition tumbler chip may have failed (requires tumbler replacement and re-set security again) Can't guarantee it will fix your problem, cause I can't see what else is going on from here...but that's where I'd go first!
I just had this same problem with a '96 . do you have a vats key in your '94? you need to bypass the VATS system. read some of the blogs on this site and it will tell you how to do it. I fixed mine with a $2 resistor from radio shack.
