Vacuums Logo
g
golda mckenny Posted on Jun 09, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What kind of dust cup do I use in the 26.0?
I have asuperlite 26.0 that needs a new dust cup, what part # should I order?
Think Crucial
Level 3:
Master:
  • Vacuums Master 894 Answers
  • Posted on Jun 09, 2014
Think Crucial
Vacuums Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711256
Points
8395
Hi, it's Jeremy from Crucial Vacuum.
The dust cup used in the Eureka superlite is the DCF- 17. The part number for this is: 63170B. Filters should be replaced every 3 to 6 months for optimal performance. For any other parts you may need for your Eureka Vacuum visit: http://www.crucialvacuum.com.
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
1helpful
Shark navigator lift away turns on but no suction
Hello, this is Ava with Think Crucial.
It seems that there may be something blocking the airway. To fix this, please make sure to unplugged the unit from the power before performing this.
There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, keep reading for other options to fix the suction.
If both your foam filter and felt filter have not been cleaned in the past month, this may be why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
If none of the other solutions worked, your motor may be bad. You would need to check with Shark about this.
If your need to replace your Shark parts such as filter, belts or hose, you can also order replacement parts directly to us. You can check our online store in this link: http://www.thinkcrucial.com/search?type=product&q=shark
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
How do I remove the dust cup and clean it?
Hey, this is Tristan with Crucial Vacuum,
In order to remove the dust cup, there's a designated lever that you slide to the left in order to pull the dust cup out. This slider is above the HEPA filter (the four holes near the bottom of the vacuum). After cleaning, you slip the dust cup back and slide the slider to the right to lock it back into place.
Below I have attached a link to the users manual for the Eureka 2997-2999 series. You should refer to page 4 to view the diagrams pertaining to my suggestions.
http://www.manualslib.com/manual/49521/Eureka-2997-2999-Series.html?page=4#manual
You can purchase replacement parts for Eureka direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html
Tristan Clausell
Where do you get filters for a EP366
TO ORDER REPLACEMENT DUST CUP FILTERS
To order, send check, money order or credit card authorization to:
EURO-PRO Operating LLC
94 Main Mill Street, Door 16
Plattsburgh, NY 12901
or call
EURO-PROCustomer Service at: 1 (800) 798-7398
Monday to Friday 8:30 A.M. -5:00 P.M. Eastern Standard Tim
Please Note:
The Shark Dust Cup Filters are washable.
Importan
Make sure that Dust Cup Filter is completely dry before inserting back in the hand vacuum
http://www.sharkclean.com/manual/EP366_(700_WATTS)_REV_0603A.pdf
1helpful
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 • Vacuums
Dyson dc 40 loses suction
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
Ava B.
My dyson hose has lost suction
Ava B.
May 14, 2012 • Vacuums
Bissell carpet cleaner does not suction
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Dyson DC32 Animal has lost suction.
Ava B.
May 02, 2011 • Vacuums
No suction on dyson dc07
Ava B.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
