Gorenje wa72145 my son put washing up liquad in washer last night all bubbles flooded out so i stoped it and emptyed all bubbles out now this morning it wont work comes up with f2 fault?
  • Washing Mach... Master
  • 825 Answers
How do reset for washing machine
I do not see a way to do a reset on this unit. This is the manual and shows what things you can try. Manuals Gorenje UK
Sep 30, 2014 | Gorenje W7543LR Red 600 mm Washer Front...
Gorenje wa 72145 my son put washing up liquard in last night and the bubbles over flowed so i stoped the washer and empyed it. This morning iv gone to use it and f2 error comes up and wont work
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Jun 09, 2014 | Washing Machines
Is not opening
Yellow Hibiscus, Mothers Day gift. My son brought it home last night.
2 blooms lots of buds. Blooms closed last night, today still not open. Transfered to larger pot. Added water and a little extra soil.
Nov 26, 2013 | Spooky House Studios UG Bubble Explode
Son put normal dish washing liquid in top draw!
ok, the machine flooded and the water has leaked into the bottom of the machine, 1st turn off the machine at the power point. 2nd- open the top drawer and remove the suds from it. 3rd. open the bottom drawer and look under it to the bottom of the cabinet . that is where the water will be. use a torch if you have to. now you need to dry the water up. you can do this with a hair dryer or a fan heater. the reason the machine is flashing F1 is because the water has triggered the flood switch and you need to dry up that water. please reply 4 more help.once dryed F1 will disappear. please make sure all the suds are removed from the top drawer. good luck
May 14, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The dishwasher fills up it starts to spray the water but after 5 seconds it emptys. It then does the other the rest of the wash normally. This happens in all modes.
Check to see if water at the base of the washer has caused the "anti flood system" to trigger. The anti flood device is a polystireene float and micro switch that does trigger (and puts the washer in pump out mode) once water via leak or spill is detected. You can tilt the washer to 45 degrees and check if a small amount of water comes out of the bottom. As you indicate that the washer emptys after 5 sec I do think that the anti flood system is causing this.
Apr 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My washer is a kenmore and it stoped spinning last night. The motor is running but its not washing? What should I do?
sounds like you have a broken coupler, this conects the motor to the transmission, if the agitator is not moving and the unit is not spinning but you hear the motor this this is whats wrong. this will take some experience to replace, mainly getting into the unit and putting it back together can be challenging and can cuase problems if not done right. part is cheap though. good luck
Nov 24, 2009 | Kenmore 24032\24036 Top Load Washer
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
10 yr old Kenmore 70 series top load washer
Sounds like either the water level sensor (called a pressure switch ) is malfunctioning or there is a mechanical problem with the switch meaning that the tube that goes from the switch is
a) Kinked or crushed
b) has a small hole
c) Has become clogged
d) Air dome (where tube goes to on outer tub) is clogged
Jan 19, 2008 | Washing Machines
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
