SOURCE: sound and picture interference when changing
It may be the cables you are using. You will need to HDMI cables for high def and rca or coaxil for regular
SOURCE: tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
SOURCE: Vizio VX37L HDTV black rectangle in lower right corner
Turn off the Picture in Picture (PIP) option using the remote control. I had this problem and it worked for me!
SOURCE: Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix....
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
SOURCE: vizio vx37l says it has no signal and shuts down before i can change the input
Good common sense idea and I will remember it.
