Question about Exercise & Fitness
Lowest speed of elite personal trainer tm500 too fast.
I am unable to lower the speed of the treadmill below a fast walk. Speed control is at it's slowest speed point. I cannot determine who makes this treadmill and would like to know that as well.
It requires a drive belt adjustment. Gain access to the motor and belt (Disconnect from power supply first!) and reajust belt tension.
email me on mickey67@tpg.com.au if you need help. It's not too difficult a job.
Posted on Jul 26, 2010
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
My Golds Gym trainer 480 treadmill minimum speed is 3 miles at lowest setting and it will not slow down when pressing the down arrow
Gold's Gym Treadmill Product Support ' ManualsOnline.com
fitness.manualsonline.com/support/golds-gym/treadmill/
My goldsgym treadmill just goes up and down when t. Gold's Gym ... my treadmill walking belt will not turn. ... Golds gym trainer 480 start button stopped working.
Repair Your Own Treadmill With Mark Peterson - YouTube
? 1:16
https://www.youtube.com/watch?v=B997gX07hW4
May 6, 2008 - Uploaded by Mark Peterson
A certified Fitness Specialist by the cooper clinic in Dallas, and a personal trainer for the first 16 years of my fitness career. .... I purchased a used Golds Gym Treadmill model# GGTL396100 which I tested when buying ... The treadmill will fully incline thennot go down, I have tried to recalibrate the incline ..
Nov 26, 2015 | Exercise & Fitness
How to recalibrate 8600 incline trainer
To initiate the calibration routine, hold down the SPEED +
button and the SPEED - button simultaneously for three seconds. During the calibration routine, the INCLINE
TRAINER will automatically rise to the highest incline level and then return to the lowest incline level.
P.S. This is listed in your user manual in the "Troubleshooting" section if you don't have a user manual then you can get a pdf copy of it here
http://www.ereplacementparts.com/images/nordictrack/CTK59020.pdf
Aug 31, 2014 | Nordic Track NordicTrack Treadmill, A2550
How to recalibate a pro-form 595LE treatmill.
follow this steps and fix it. God bless you
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Dec 09, 2013 | Proform 595LE Treadmill Walking Belt
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
X9i incline trainer clicking
Step 1:
RUN the calibration software . and fix it. God bless you
15.If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
Feb 07, 2013 | Nordic Track Incline Trainer X9i...
5600t speed adjust does not work
RUN the software calibration, for troubleshooting and fix it.
See the steps for calibration.
God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the
Jan 09, 2013 | Keys Fitness 5600T Treadmill Drive Motor
On power up the treadmills slowest speed is 8 klm's/hr, it can be increased to over 16 klm's/hr, but then only lowered to 8 klm's, which is to fast and dangerous to step straight onto. Is
ADJUST THE SPEED SENSOR , SEE THE DIAGRAM ATTACHED, CLEAN, AND TIGH THE CONNECTOR WIRES.
2) RUN THE SOFTWARE CALIBRATION FOR DIAGNOSE , TROUBLESHOOTING, AND FIX IT.
SINCERELY. GOD BLESS YOU
Apr 28, 2012 | Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
Find repair service for schwinn treadmill
short of changing batteries ,if you got them, theres nothing you could do other then replace it, If your speed rpms and distance doesnt read its the speed sensor
Feb 03, 2009 | Schwinn 430 Elliptical Trainer
Exercise & Fitness Logo
293 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
