Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
The kohler engine on my poulan pro 42 inch 17 hp is reving way too high the throttle cable does not apear to be stuck
  • Anonymous Mar 17, 2014
    Kohler pro 17 ohv throttle won't work
  • 127 Answers
YOUR THROOTLE LINKAGE IS BINDIND WITH THE ENGINE OFF MOVE THROTTLE BACK AND FORTH WATCHING THE LINKAGE ON THE CARB, SPRAY LINKAGE WITH PENETRATING OIL SO IT LOOSENS UP
Posted on Jun 26, 2009
I have an older poulan pro 18 hp ohv.kohler engine. Tried adjusting throttle linkage to get more rpm. the throttle /carburator linkage plate has adjustment also. In what order do you start adustments
The Kohler is design for 3600 Max rpm with it developing peak torque at 2200 rpm 42.5 N·m (31.4 ft. lb.)
If your trying to go above the 3600 rpm then your only risking damaging the engine plus causing unnessary wear and tear on it.
Apr 01, 2015 | Poulan Garden
Kohler ch740-0101 engine will not start unless assisted with charger booster. when attempting to start unassisted voltage drops to below 11.5 v and will not start. replaced batteries but problem still...
this sounds as if you have a bad cable/connection or starter relay has some dammaged contacts to be responsible for voltage drop
sometimes the wire comes loose from back of connector
Jul 14, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I need a manual for a Poulan Pro tractor 42 in. 17 h.p. model number PRK17A42ST.
hi there martin 2228
pauly 46 here
here is a web site i found , and its a close match to your model
checkn it out its a owners manual , may have what you need
download a copy
http://www.hammerwall.com/Manuals/Poulan/Description/PRK17H42STA/Poulan%20Pro%20Lawn%20Tractor/L0109173/
cheers hope it helps
pauly46
Jun 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
The engine of my Poulan Pro 600 is over reving.
Check carburetor/throttle to governor lever linkage.
Jun 12, 2010 | Poulan Pro " Pro" Self Propelled Mower
Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
Jul 03, 2009 | Oregon Scientific Oregon Fusion Blade For...
Hard to shifet my poulan pro and wont go into reverse
Try loosening the belt tension to the transmission a little bit. Some of these are just stiff and you have to slip the clutch a little to rock them into gear.
May 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
684 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
